Riddle me this- front wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jethro, Dec 4, 2013.
  1. Dec 7, 2013 at 4:33 PM
    #101
    Pearcem87
    Pearcem87 Well-Known Member
    2013 TRD Off Road
    I think a big part of the idea that FWD > RWD for the snow is the average driver's pucker factor. If my car understeers, and seems to just slide a bit and not turn as much as I would like, I don't think that's particularly scary unless you are speeding, etc. With RWD, if the back end gets a little loose, I think the average driver would probably say that is a more drastic feeling change or more pronounced change than understeer, especially in the snow.
    I had a 328i with sport tires. That was my first RWD only vehicle, and I happened to live up in Quantico about 5 years ago. I drove around a lot in 3 different snow storms, including one where I drove home to SC, and I-95 was snowed over down to about Petersburg. I only had an issue once time when I went up a hill I had no business trying to go up. The car got sideways plenty, but luckily I had some experience and skid pad training to know what to do about it.
    My guess is the average driver doesn't have the snow experience or driving knowledge to know how to correct some oversteer, and let's face it, if you don't know how to fix it, oversteer can be pretty scary, especially when it is unexpected or the conditions are bad.
  2. Dec 8, 2013 at 3:20 AM
    #102
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    I rented a Mercedes B Class in Germany in 2011 and a SEAT Ibiza in Ho;;and in 2012. Both of these are front drivers.
  3. Dec 8, 2013 at 5:16 AM
    #103
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    MB still is but the numbers are dwideling MB gets around it with AWD. You can rent any thing you want there is some thing for ever one but the numbers of FWD cars are far greater than RWD even in Europe where they like to drive fast and take chances.
  4. Dec 8, 2013 at 8:01 AM
    #104
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    You need a solid rear axle for heavy towing and it would be quite silly to put a solid front axle up front and independent CV driven setups out back. Plus the durability of a solid axle can handle heavy loads much better. All modern pickup trucks still typically have a solid rear axle for this reason. As far as I know, Jeep Wranglers are the only vehicles still made with solid front and rear axles, which is about to be a thing of the past in the next few years when the new CARB fuel economy standards become law.
  5. Dec 8, 2013 at 8:18 AM
    #105
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Ram power wagon?
  6. Dec 8, 2013 at 8:23 AM
    #106
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, All RAM 4x4's are solid front/rear axels.
  7. Dec 8, 2013 at 7:16 PM
    #107
    WOODEX M.E.
    Corey
    Maine
    I figured they were but wasn't sure so i just went with the gimme option.
  8. Dec 8, 2013 at 7:22 PM
    #108
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Ford F series (f-250 and above)
  9. Dec 9, 2013 at 9:14 PM
    #109
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Great for tearing up parking lots, or going to the ski hill. But mountain roads with feet of snow... I'll take the taco. How's the coast been for snow this year Oz? I'm lovin the interior's forest service road snow wheelin'
  10. Dec 9, 2013 at 9:17 PM
    #110
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hardly any snow so far , colder than usual though
  11. Dec 10, 2013 at 6:10 AM
    #111
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Twin stick t-case upgrade and just settle this!
  12. Dec 10, 2013 at 8:03 AM
    #112
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Bottom line really is a FWD will get you GOING in most situations a lot easier than a RWD, but once moving is where the FWD loses its advantage because of understeer, witch is where a RWD would be easier to control in turns and so forth. So there are pros and cons to both sides of the argument, witch one you like better just simply comes down to personal preference.
  13. Dec 10, 2013 at 10:51 AM
    #113
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    But in the winter time, if your front end is sliding, there's the old Han Solo expression.. Punch it Chewie! FWD = good RWD = bad.
  14. Mar 29, 2014 at 12:34 PM
    #114
    2004TacomaSR5
    Jon
    Montana
    One cool thing you used to be able to do with old 4x4's that had locking hubs was if you threw a driveline, you could lock in the hubs and put it in 4hi and get home that way. Doubt you could do that on these modern setups though without hubs and IFS.
    There was a time when everything was rear wheel drive and took more skill to handle, and then FWD came along to make it easier for the morons to get around with. During the 60s, people used to drive 400 horse muscle cars all over during the winter and as long as they kept good tires on them and drove them carefully, they didn't have problems. Times have just changed. Personally, I don't mind either setup. In most cases, a FWD car with good tires on it gets around better on ice than 4x4 trucks do.
  15. Mar 29, 2014 at 1:25 PM
    #115
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    This.
    I had a Jeep Wrangler that I installed a beefier rear axle shaft kit from Warn. It had and required the use of locking hubs. You could unlock the hubs, put it in 4 wheel high and run on front wheel drive. I did it once. It worked fine. Can't remember exactly why I tried it but it was fun to see.
    What was funny is that there were locking hubs on the rear but not the front. Got some weird looks and questions when someone noticed.
  16. Mar 29, 2014 at 5:04 PM
    #116
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Dayum, that's a blast from the past - nice lookin Fiero! :D
  17. Mar 29, 2014 at 7:09 PM
    #117
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    Had a GT with the V6 for a couple years way back in time. That was a fun car. If you played the clutch just right you could literally lift the front wheels off the road!!!! That thing had some wicked under steer though... No weight on the front end at all. I take that back, the radiator and spare tire were over the front wheels. ;)
