ride differences in OME dakar and flattened out Stockers
Discussion in 'Suspension' started by ComaTosin, Feb 23, 2009.
  1. Feb 23, 2009 at 9:14 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    as we know by now - I have 2" blocks under my non TSB rear leaf springs. they are flattened out - completely. What differences would i notice in ride if i changed to the Dakar springs? I would like something that rides smoother and soaks up the bumps a bit more. Is the fact that these are flat inhibit them from performing entirely? or can they still perform by creating a negative arch?
    thanks.
  2. Feb 23, 2009 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The springs on the Tacoma are pretty close to being flat. Give better flex off road. If you swap out to the Dakar springs, it would be a little more firm on the raod, and depending on the shocks you used, it would handel better off road.
  3. Feb 23, 2009 at 6:16 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    that is what i was htinking. I hoped to get something that was a bit more cushy on the road - that would be Alcan i guess but i also want to be able to haul the bike with more stability.
    I guess I can not have it all. decisions decisions......
  4. Feb 23, 2009 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alcans are going to be the same as the Dakars.
  5. Feb 23, 2009 at 6:56 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    thought they provided a softer ride but decreased ability to haul......
  6. Feb 23, 2009 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They decrease the ability to haul because they eliminate the overload leaf. That lets them flex a little more when off roading.
  7. Feb 23, 2009 at 7:14 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    you think dakars with proper OME shocks would be an improved ride over flat springs/block and over extended TD Billy's? Trying to figure out what to expect for the money. i am okay with spending the money but only if it will be noticable improved. I am only moderately impressed with the difference in the toytec C/O and TC UCA compared to the daystar Urethane spacer. Goes without saying that I am only intown right now - no off roading since the new components in the front.
  8. Feb 23, 2009 at 7:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think it would be.
