ride harshness on 886s without steel bumper or winch
Discussion in 'Suspension' started by ross123, Jan 24, 2012.
  1. Jan 24, 2012 at 6:14 PM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    ok so i bought a full OME lift kit with 886s because i also bought a relentless bumper and a winch. now my question is my lift, rims, and tires will be in this week. but my bumper will take up to 4 months. how bad will the ride be if i install everything now before i put the bumper or winch on? should i just wait and do everything at once?
  2. Jan 24, 2012 at 6:17 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm be more concerned with the amount of lift you'll get with 886's in an unloaded Tacoma more so than the ride. It'll ride stiff, but you can live with that. The bigger concern would be getting over 3" of lift and causing damage to the drive line components.
  3. Jan 24, 2012 at 6:18 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    it will feel like there is no suspension at all and you may knock your teeth out when you go over bumps. seriously. but go for it.
  4. Jan 24, 2012 at 6:20 PM
    ross123
    fort bragg
    yeah im leaning towards just waiting till everything arrives. i was just curious what you all think
  5. Jan 24, 2012 at 6:23 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Its gonna be rough as hell. At least until you get your weight in it.
  6. Jan 29, 2012 at 4:50 AM
    ross123
    fort bragg
    so i got everything in the mail. anyone know how much lift 886's give with no weight up front? and if it can do any damage to the vehicle?
  7. Jan 29, 2012 at 7:17 AM
    Pugga
    Massachusetts
    I'd guess a little over 3". They're 10mm taller than the OME 885's and also have a stronger spring rate. The 885's give about 2.5" of lift so add 10mm to that and you're at 3" and up the spring rate, you'll be over 3".
    The damage you can do with that kind of lift is causing the CV joints to operate at an angle much steeper than they'd like. Also, the boots can tear from being at that angle and they're a pain in the ass to replace.
  8. Jan 29, 2012 at 7:20 AM
    ross123
    fort bragg
    yeah doesn't sound worth it to me. ill just wait till the bumper gets here
  9. Jan 29, 2012 at 8:02 AM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    I have an access cab with a stock bumper. I have 886's with the toytec spacer. The only added weight up front is an all-pro skid plate. In my opinion, the truck rides fine. I've put over 10k miles on it like this. I do however, have LR uca's. I say just do it now.
  10. Jan 29, 2012 at 8:34 AM
    Pugga
    Massachusetts
    What do your CV angles look like and how much lift did you get out of that set up?
  11. Jan 29, 2012 at 8:38 AM
    steve103
    steve103 Well-Known Member
    steve
    santa cruz ca
    07 taco
    arb bumper,bilstein shocks,886 ome springs,ar mojove rims,2optima batteries,custom electrial.on board air,cb,14gal frontrunner water tank,frontrunner roofrack
    ome stuff does not put to much lift on the rig. 2 to 3 max. love mine with arb bumper.
  12. Jan 29, 2012 at 8:43 AM
    RCL
    RCL Well-Known Member
    Bob
    Oklahoma
    2010 TRD Dbl. Cab
    Winch
    I have the 886 and ARB bumper.
    Ride is firm which I like.
    No problem with boots or cv angles and alignment was easy.
    Now have about 35,000 miles on this set up on a 2010 Double Cab.
  13. Jan 29, 2012 at 8:53 AM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    I did just the opposite of what you did. I had my ARB bumper on stock suspension for a little while before i went with OME 886 front and rear with dakars in the back. the ride is a bit stiffer with the bumper and winch on, which i like.
  14. Jan 29, 2012 at 10:59 AM
    ross123
    fort bragg
    i have LR UCA's that ill be putting on aswell
  15. Jan 29, 2012 at 11:57 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    What is your Taco (RC AC DCSB DCLB)?The ride will still be stiff with 886s a Relentless Bumper, winch, Bud Built skids & Sliders. A local had all that with 886s and said "it felt like I was being assaulted". So he switched to 885s with 1/4" spacer.
    It depends on what you put them on. 885s on my 4Banger AC got me 3", and got OZ 2 1/2" on his DCLB.
  16. Jan 29, 2012 at 12:12 PM
    Pugga
    Massachusetts
    Correct. Op has a double cab so the measurements I gave him were based on OZ's measurements with his double cab so 886's should put him at, if not a little over, 3" of lift unloaded.
  17. Jan 29, 2012 at 12:16 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    I've got 886 coils on my DCSB with CBI front bumper and Warn 8000lb winch with synthetic cable. Even after about 15000 miles on the lift I have at least 3" of lift. My CV angles are a little excessive, the ride is very stiff, and there is barely any articulation while off roading with sway bar installed. I plan on buying a set of 885 coils in the spring and installing them to see if the ride improves.
  18. Jan 29, 2012 at 12:21 PM
    4Wheelin4Banger
    Randy
    Don't see where he mentions DC & it's not in his profile.
  19. Jan 29, 2012 at 12:22 PM
    Pugga
    Massachusetts
  20. Jan 29, 2012 at 12:32 PM
    4Wheelin4Banger
    Randy
