Ride Height 2015 tacoma pro
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John G, Sep 1, 2016.
  1. Sep 1, 2016 at 9:04 AM
    John G
    John G [OP] Member
    NH
    2015 Tacoma PRO Inferno
    Polk Audio, Wet Okole custom seat covers
    Hello everyone, Just joined the site. I have a 2015 tacoma pro, and was looking at the way it sits. The front sits great with the suspension,the rear seams to sit level instead of a little higher like most pickups. Does anybody know the height from the ground for my truck to top of bumber or center of hitch ? Or is this the way the truck is suppose to be. It rides great and everything is stock. Thanks for your help, John G.
  2. Sep 1, 2016 at 4:39 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Welcome to the club!
    Your Pro has a 1.75" lift in the front that levels it compared to the rake that the Sport and Off Road have. A lot of new truck owners run out and get a leveling kit installed to make their truck look like yours does.
  3. Sep 1, 2016 at 4:43 PM
    John G
    John G [OP] Member
    NH
    Hi Ryan, then i should probably should leave it stock then. I'm use to trucks having a slightly higher rear. Thanks, John
  4. Sep 1, 2016 at 4:46 PM
    RyanL
    Indiana
    It's your truck, you can do whatever you want with it. But if I were you I'd live with it for a bit before making any drastic changes, and in the meantime browse some threads about dudes going crazy because their aftermarket leafs won't stop squeaking.
  5. Sep 1, 2016 at 4:47 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You can put something like an icon progressive leaf in the rear. Will yield between 1.5"-2" of rear lift. They ride nice.
  6. Sep 1, 2016 at 5:01 PM
    John G
    John G [OP] Member
    NH
    I like the way it rides now, not sure if aal would change the ride . the side profile is level. I guess my past trucks always sat up a little higher in the rear. Thanks, John
  7. Sep 1, 2016 at 5:09 PM
    moondeath
    Pa, Gardners
    Single aals will ride terrible. Multi leaf packs ride much nicer. I just installed the icon progressive I spoke of earlier. Its a 3 leaf that is used with all the factory leafs, except the overload if you dont want that .5". It rides better than stock.
  8. Sep 1, 2016 at 5:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Any reason you went with Icon?
    Wheeler's/HeadStrong/ToyTec/Icon all use the exact same springs for the 3 leaf AAL (and the same manufacturer and specs). Icon was/is like $40 more than the lowest priced company.
  9. Sep 1, 2016 at 5:12 PM
    RyanL
    Indiana
    The Pros ride very nice stock. Unless you want more lift, well "if it ain't broke..."
    Companies sell stuff like this for non-Pro trucks so they'll LOOK level like yours does: http://www.lowrangeoffroad.com/lrt-...a-tacoma-by-low-range-off-road-lr-lrtaco.html
    And it costs a lot more than that for the full upgraded suspension you already have.
  10. Sep 1, 2016 at 8:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I did the same and the rear rides better than stock.
    https://www.tacomaworld.com/threads/baja-tx-pro-kit-icon-aal.385619/
