Ride height measurement stock vs. lifted
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, Nov 2, 2010.
  1. Nov 2, 2010 at 1:19 PM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Need a little help here guys, I recently bought a 03 TRD Tacoma that came with a fabtech lift. The front shocks are shot, and am currently trying to piece together some TRD coils with Bilstein 5100's. I'd like to keep the same ride height so I turn to you all to give me specs.
    Measuring from the center of the hub to the top of the fender well, I get:
    22 3/4" driver side
    23 1/4" passenger side
    So for those of you who have billy's can you please chime in and relay your measurements? Also let me know what setting they are on. Important to measure from said points since my tires are 285's and measuring from top of tire or ground won't be accurate. If your truck is stock height let me know what that measurement is too.
    Thanks much
  2. Nov 5, 2010 at 7:02 AM
    NegroTundra
    Land of Enchantment
    Come on guys help me out here. Someone with billy 5100's on top notch chime in! Whats you measuement hub to fender well???
  3. Nov 5, 2010 at 7:58 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Iam at work but I will look in my notes when I get home. I will reply you about 4:00pm. AZ. time
  4. Nov 5, 2010 at 12:54 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    Im stock, and just measured them at 20 3/4"... I have well guards on still, so maybe add 1/4"?
  5. Nov 5, 2010 at 3:28 PM
    NegroTundra
    Land of Enchantment
    well guards? Are you talking bout the fender flares? Thanks for that. So it seems my fabbys are netting me approx 2.5"-3" lift.
  6. Nov 5, 2010 at 4:42 PM
    tacoma guy
    Joe
    Phoenix Az.
    Hay bud,sorry running a little late. When my truck was stock, with about 19000 miles on it. It was 35&13/16in. drives and 35&7/8in. pass. side. Now that was from the ground to the bottem of the fender well opening. With chrome trim. No fender flaers. Hope that helps..:)
  7. Nov 5, 2010 at 4:48 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just set the 5100's at 0 and get the Eibachs I got 3 1/2 with that setup.
  8. Nov 5, 2010 at 8:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    FWIW I'm at 22 7/8 on both sides (the beauty of adjustable COs). Based on pre-lift comparison, that is right at 2" over stock.
  9. Nov 5, 2010 at 8:43 PM
    NegroTundra
    Land of Enchantment
    I hear ya on the adjustables. Thats what I have now but they are corroded beyond ability to adjust. Had ICONS on my Tundra before this Tacoma purchase..so point bein I'm aware haha. Thanks guys appreciate the info....not as hard into high speed wheelin as I used to be so billy 5100's ought to do fine.
  10. Nov 6, 2010 at 6:06 AM
    JBear
    Orange County, CA
    Lol... I go all the way outside to do the guy a quick favor, and in return I get a proper grammar lesson... Nice! There is an A in bout, my friend... and you could have a 6" lift... but it would still be fabtech. Just sayin'.....
  11. Nov 6, 2010 at 8:53 AM
    NegroTundra
    Land of Enchantment
    don't take that too personally, I was just confused as well guards are the plastic liners inside the fender well that my truck has...was just clarifying! No DB lift here my friend....and the fabtech's are going to be the first thing gone!
    Anyhow, I do appreciate your help
  12. Oct 30, 2017 at 5:50 AM
    tunerboy
    tunerboy New Member
    Ken
    03 Tacoma dual cab
    I don't know if anyone will look at this old thread... there is a useful # of front ride height (axle center to fender opening), does anyone have similar numbers for the rear ? we recently bought an 03 with King coilers and possibly Deavers rear springs. just trying to determine how much it is lifted over stock. it has the wrong rear shocks and I'm hoping the Fox IFP Smooth Bodies will be long enough. cheers, Ken
