Ride Heights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdub, Aug 5, 2011.
  1. Aug 5, 2011 at 1:18 PM
    jdub
    jdub [OP] Well-Known Member
    White SR5 PreRunner
    So i'm trying to figure something out. I've searched around and it says that the prerunner sr5 height is the same as a prerunner sr5 with trd package. I'm curious because every time i pull up next to a tacoma with the trd package...it always seems to be higher? Reason why i ask is because i'm looking to get a 3" procomp suspension lift and i'm wondering if getting the lift will make my ride height higher than a taco with the trd package? or will it be the same. Sorry if this sounds like a noob-ish question but i'm curious!
  2. Aug 5, 2011 at 1:20 PM
    Manwithoutaplan
    ID
    what size tires are you running right now???
  3. Aug 5, 2011 at 1:22 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    most likely tire size... also your suspension could possibly be blown... my dad has an 05 DC tacoma and i have an 09reg cab and mine sits higher than his. we have the same size tires but mine are ATs while his are HT tires
  4. Aug 5, 2011 at 1:30 PM
    Manwithoutaplan
    ID
    true that X2
  5. Aug 5, 2011 at 1:56 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You have the same coils and leaf springs on your SR5 as a TRD Sport. The suspension in your '08 might have sagged quite a bit as mentioned above.
  6. Aug 5, 2011 at 5:13 PM
    jdub
    White SR5 PreRunner
    Hmm right now my tire size is 265 65 r17's
  7. Aug 5, 2011 at 5:14 PM
    jdub
    White SR5 PreRunner
    Also is a 3 in lift put my truck higher than a truck with the Trd package?
  8. Aug 5, 2011 at 5:18 PM
    Pugga
    Massachusetts
    F-150 Mod
    Your truck when it was in it's new form was the same height as one with the TRD package. If you're lower now, it's because your suspension has sagged. That being said, any lift would put you higher than a TRD package equipped Tacoma. The only difference between the TRD and a non-TRD is the shocks and the sway bar (as far as suspension is concerned, there are other mechanical differences). The coils and leaf springs are identical to those that came on a TRD Sport.
  9. Aug 5, 2011 at 5:18 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2010 TRDOR MGM DCSB
    ARB bumper, King RR with 700lbs coils, Dakars, lr ucas, 1 piece driveshaft, softopper, 285/70/17 KM2, SCS F5s, BAMF sliders, Allpro rear w/ dual swingout
    a 3" will put you higher than a stock trd. as previously mentioned suspension is the same except the shocks.
  10. Aug 5, 2011 at 5:19 PM
    GreatBasinTaco
    Reno, NV
    2010 TRDOR MGM DCSB
    beat me too it, but yes
  11. Aug 5, 2011 at 5:23 PM
    jdub
    White SR5 PreRunner
    thanks guys! that was plenty of help. that's another reason why i love this forum!
