Ride Quality or Fact of Life? -- 2" OME Lift with 33" KO2's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbell502, Jun 28, 2021.
  1. Jun 28, 2021 at 7:32 PM
    tbell502
    tbell502 [OP] Active Member
    2005 Tacoma TRD Off Road
    Thank you for the link! Do you have any personal experience with Balance Beads? This is the first I've heard of them. Is it really better than getting my tires balanced at shop via Road Force Balance?
  2. Jun 28, 2021 at 7:38 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I ran 35in cooper mud tires on my last truck. And thats how my mechanic balanced them. It was amazing how well it worked.
  3. Jun 29, 2021 at 7:56 AM
    tbell502
    So I just watched a video on installing the checkered flag beads. Is it really as simple as breaking the tire bead and dropping the tire beads in and then reinflating the tire?
  4. Jun 29, 2021 at 8:01 AM
    Mark77
    Mark
    Nothing yet
    From what i have aeen, ypu use a funnel and pour them 8nto the valve stem q the schrader valve removed. Unsure if it will work that way w the tpms.
  5. Jun 29, 2021 at 8:19 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Yes, but you have to make sure there is no bead lube on the interior of the tire when you re-seat it. I use 6oz of Dynabeads in each 285/75r17 tire. Here's a pic of the tiny size of the Dynabeads, which is why you can also install them thru the stem:
  6. Jun 29, 2021 at 8:25 AM
    bboggio28
    bboggio28 Well-Known Member
    2020 TRD Sport
    you said it only occurs at high speeds on highway. I remember watching a TacomaBeast video where he had to replace the driveshaft due to the angle produced by his lift, wheels, and tires but that was at low speed and/or during acceleration.
    Mark77 likes this.
  7. Jun 29, 2021 at 9:40 AM
    Ryans4×4
    Ryans4×4 Well-Known Member
    Maryland
    2014 Tacoma sport double cab
    Kicker stereo system,5100s, 885 coils jba uca's, 285 75 16 stt pro's
    The eggs bushing fixed my vibrations after lifting
  8. Jun 29, 2021 at 11:00 AM
    tbell502
    Oh this is great to see! This seems pretty straight forward, especially if I don't have to break to the tire bead.
    And call it a rookie mistake -- I never realized tires are supposed to be balanced every 3-6k miles ("palm to face"). It's been just over 5k miles since the tires were last balanced. This has me thinking it is likely a balance issue (or at the very least part of the issue). I'm now very interested to see the impact balance beads will have :).
    As for ECGS bushing -- I don't think this is the issue because at low speeds (<30 mph) I have no vibrations (other than road feedback from E-rated tires). I really only feel the odd vibrations at highway speeds (50+). Plus there was no difference between 2hi and 4hi. However, after doing research, I still intend to do this mod, along with replacing the carrier bearing plus bearing drop, and likely shim the rear axle.
    If all it ends up being is a tire balance issue, it seems that the other mods are at the least preventative because of the slightly adjusted driveline. Am I thinking right here?
  9. Jun 29, 2021 at 11:06 AM
    Twitch896
    Twitch896 Member
    06 dclb
    Ome lift all around with dakar leafs 17” kmc Rigid fogs
    Only issues i ever had like this were the ball joints and alignment. Ran the full OME kit. Jba uca with moog ball joints after the ball joints went twice, until i switched to their HD balljoint. Do you grease the bj often? What spring rate you running for the coils?
  10. Jun 29, 2021 at 11:10 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I chased a random vibration with my truck and measured the driveline angle multiple times, tried multiple known fixes and finally did the ecgs bushing and it fixed the issue. Could feel the vibration in the steering wheel at time, in the floor or the seat and it all went away after doing the bushing. If your truck is lifted it's worth doing to rule it out.
  11. Jun 29, 2021 at 11:14 AM
    Buschman
    Buschman Well-Known Member
    Oregon
    1998 Tacoma V6 4x4 5speed
    Kings, TC uppers , TRD rear end, 4.30s, 285's
    I had 285 KM2s on my 1st gen and it always had vibrations at certain speeds no matter how many times I rotated/balanced them. This year I bought some Cooper STT Pros in the same size and load rating 100% better.
    Mark77 likes this.
  12. Jun 30, 2021 at 2:27 PM
    tbell502
    So I’ve done some research on balancing beads. Question:
    is there any issue with putting in balance beads with mileage on the tires? Most people I’ve seen that use them seem to put them in at the beginning when they mount brand new tires.
  13. Jun 30, 2021 at 2:29 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Have you tried to adjust air pressure yet? You could save a lot of trouble if you have not and it resolves you issue.
    Just my 2 cents, and I am in debt.
  14. Jun 30, 2021 at 2:38 PM
    LC7
    Far Nor Cal
    I can't say for sure, but I used them when I had new Cooper ST Max skinnies installed on my sport rims, then swapped those used tires to SCS F5 rims many miles later later with fresh balance beads. I didn't experience any difference. My YouTube-Certified Engineering degree says the inside of the tire isn't affected by outer tread wear, but idk.
  15. Jul 12, 2021 at 9:21 AM
    #35
    tbell502
    An update for anyone still interested:
    Turns out my tires were way out of balance. So I got them road forced balanced which has made a huge difference. However I still have some slight (and I mean slight) shaking at highway speeds.
    So I have 2 thoughts:
    (a) it is my understanding the KO2’s suck to balance. The tire mechanic explained that this is largely due to the KO2’s construction. They are two halves which are sealed together, thus creating a high point in the center.
    Because of this, the mechanic explained that he can get most the shake out, but may not be able to get it perfectly smooth.
    So this maybe as good as it gets with my current tires.
    (b) I am going to investigate my driveline. I do have slight play in the carrier bearing. Not sure if this is normal, but when I pushed on the driveshaft I was able to move the shaft around a half inch or so where the carrier bearing is. I’m going to also analyze the driveline angles (found a great thread I saved somewhere here on TW), and from the analysis hopefully I’ll be able to determine if everything is good, if I need to shim the rear axle, or drop the carrier bearing (or both).
    If half-inch play in the carrier bearing is NOT normal, then perhaps that is my key?
    Finally, while I am going to do the ECGS swap, I’m doubtful this is an issue as the 4hi diagnostic does not change anything.
    Thank you everyone this far — my ride is already improved!!!!
  16. Jul 12, 2021 at 10:04 AM
    #36
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    does the shaking come and go or is it always there and at what speed?
  17. Jul 12, 2021 at 10:08 AM
    #37
    tbell502
    It’s always there, and I’d say now becomes evident at around 55-60mph. But much subtler than before the balancing.
