Ride quality, Which model Tacoma is best?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Versus65, Jun 23, 2019.
  1. Jun 23, 2019 at 3:17 AM
    Versus65
    Versus65 [OP] Member
    Hey all there may be a thread about this already but i am having a hard time finding it so i apologize in advance if there is. Anyone out there drive their Tacoma's on real bad unmaintained roads, 100% of the time and every day. I am thinking of switching over to Tacoma from a 3/4 ton duramax for a work vehicle in the oil fields in New Mexico. The truck is just getting beat up and its bad enough to where going slow doesn't help. Dealing with unmaintained roads for the most part daily and just getting tired of high maintenance costs and frankly getting my ass kicked driving. Im gonna give up towing capabilities i have now but a better ride would be worth the sacrifice and i have another 3/4 ton to use to tow. Mainly just hoping to get some advice on ride quality on these Tacomas. Currently leaning toward a basic SR5 crew cab 4WD unless there is a case to go with a more costly model, it is a work truck after all. In fact i have heard from some sources stating that the TRD's can actually be stiffer due to them being designed for higher speeds in which case that wouldn't be favorable for me. I have got a lot of good reviews from friends but I'm hoping to hear from some people who have to drive them frequently in bad conditions to get some feedback on if its worth making the switch. Also curious to how well they take the constant abuse. Appreciate any advice you all could give me. BTW the trucked isn't loaded down with any weight just some light tools, its for transportation between sites!
    HoboDave likes this.
  2. Jun 23, 2019 at 3:53 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    the PRO rides best.. but cost the most
    Versus65[OP] and 18CavalryTaco like this.
  3. Jun 23, 2019 at 3:54 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
    Versus65[OP] likes this.
  4. Jun 23, 2019 at 4:14 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Sounds like you are looking for an SUV; something with balloon tires and softly sprung.
    GillyLink, CedarPark and monkeyface like this.
  5. Jun 23, 2019 at 4:22 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Double cab long bed, you can always upgrade the suspension to your own needs.
    deuceb likes this.
  6. Jun 23, 2019 at 4:26 AM
    Tacoma2020
    Tacoma2020 Well-Known Member
    I would probably recommend a SR5 DCSB 4x4 and spend some money on quality suspension and tires.
  7. Jun 23, 2019 at 4:50 AM
    GA_Goat
    GA_Goat Well-Known Member
    Bill
    Georgia
    2018 TRD Pro
    Welcome!
  8. Jun 23, 2019 at 4:51 AM
    hoch
    hoch Well-Known Member
    Desert
    18 DCSB OR 6MT
    I wouldn’t even recommend a Tacoma. There is a reason you don’t see them on oil fields or construction sites.
  9. Jun 23, 2019 at 5:55 AM
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    What's the reason?
  10. Jun 23, 2019 at 5:59 AM
    camillethetoy
    jeremy
    KCMO
    98 T100
    Good ole SR5 if you can find one, if you beat those shocks stupid, just get new ones. You shouldn't if not overloaded..
  11. Jun 23, 2019 at 6:27 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Had a sr for 3 years and it is STIFF.
    Sr sr5 and limited have same shocks.
    Now I have trd off road and it is softer
    Trd sport is also stiff
    Trd pro wasn’t an option for me so don’t know.
    Versus65[OP] and shakerhood like this.
  12. Jun 23, 2019 at 6:33 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    This. SR5 with $1500 in mods would handle the rough stuff the best.
    Spare Parts and Versus65[OP] like this.
  13. Jun 23, 2019 at 6:50 AM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    I just bought a TRD 4X4 Off Road. My research prior to purchase revealed that the Bilstein shocks that come with the OR offer the softest ride. This is presumably done to best handle off road potholes and other obstacles at fairly high speeds. The much more expensive Pro has greater suspension travel, but due to higher price, I didn't bother to research differences in ride quality since there was no way I was going to spend an extra 10 grand++ for a Pro.
    For the OP, I would suggest researching something like a Kelderman Air Ride Suspension for his current truck rather than buying something new. https://kelderman.com/shop/ I have Kelderman air bags on my '91 Dodge Cummins pickup with a 6" bag beside each front shock and in the rear a single 10" bag on a dual hinged assembly where the spare tire used to go. It turned an empty truck ride that resembled a buckboard into a floaty boaty cruiser and it acts as a load leveler with my 3,000 lb camper on board.
    Versus65[OP] and rev25sharp like this.
  14. Jun 23, 2019 at 6:54 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Yes, what's the reason?
    By the way, no oil fields in my area, however I see Tacomas on construction sites all the time.
    deuceb and Thegenerik1 like this.
  15. Jun 23, 2019 at 6:58 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Every construction site I’ve ever been on had guys driving Tacoma’s. They aren’t the “work” truck but they are used heavily by construction workers.
    deuceb and Versus65[OP] like this.
  16. Jun 23, 2019 at 6:58 AM
    Shellshock
    Iowa
    :confused: I’ve seen plenty of them
    deuceb, Versus65[OP] and stun gun like this.
  17. Jun 23, 2019 at 7:39 AM
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    Make sure you don’t like the Tacoma. It has a Transactional purpose. It is no longer personal. Will it hold up better? I don’t know. These roads beat everything up, vibration dust.
    I used mine for a few months and decided to take a company f150 because I could not see my own vehicle as a depreciable capital expense,
    For a vehicle you know you are going to eventually destroy I recommend the f150
    Here are some facts. I use my Tacoma to get back and forth to the Basin now but use the full size f150 to get around the field.
    An f150 4x4 with the 2.7 eco boost can be had for similar pricing.
    Cab space becomes important in the oilfield hauling paperwork ppe, supplies and a few tools. The F150 wins there. The extended cab f150 has much more space and utility in the cab than the double cab Tacoma.
    Lease road drivability
    Many lease roads have 20 or 25 mph speed limits. The Ford can set cruise at those speeds. The Tacoma will not set until 29 mph.
    Ford has Apple CarPlay and displays your well nav application maps on the display. The Tacoma does not.
    Windshield repair in the basin will have a large supply for the Ford.
    Although the Taco a is better on technical off-road use, the F150 StX I use at work rides better on caliche lease roads. Probably the wheelbase.
    The seat size and position in the f150 for getting in and out at multiple sites a day is superior. Your back will appreciate it.
    The thing I don’t like is the f150 I have doesn’t have the Toyota safety sense for self pacing cruise control.
  18. Jun 23, 2019 at 7:49 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    My only Tacoma ride experience is from driving my TRDOR. I found the ride surprisingly comfortable last time I took the truck on a trail. Didn’t even bother airing down.
    If it stops raining, I plan to take it back on the trail this afternoon. I’ll double check on the ride, but the first time I thought it was pretty good.
    61162001_10156710725507600_7268815953264_8399579e7780b0aaee97094d9e40b922674ce269.jpg
  19. Jun 23, 2019 at 7:58 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    You need an OR. Get those nice Bilsteins and Kevlar tires.
  20. Jun 23, 2019 at 8:25 AM
    Steemax
    Steemax Well-Known Member
    SoCal
    2019 Cement TRD OR 4x4 DCSB
    The Pro and OR will have the better comfort off road, the SR and Sport will handle better on road but are stiffer.
