Ride Rite Installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcayce, Mar 14, 2010.
  1. Mar 14, 2010 at 11:57 AM
    jcayce
    jcayce [OP] Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Stupid question 1: I want to install these air bags and am under the assumption that I can just remove the bumpstop instead of cutting it off. Should the wheels be on the ground and level when I loosen the leaf spring u-bolts (to remove the bump stop)or should it be up in the air with jack stands under the rear? I can't seem to visualize which one of these ways will be worse than the other...
  2. Mar 14, 2010 at 11:59 AM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    I took a look at some schematics and I think on jack stands is my best bet.
  3. Mar 14, 2010 at 12:03 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The kit for Tacomas comes with instructions... I had mine installed by Off Road Warehouse in Escondido, so I can't tell you too much more... but they worked great at correcting the soft spring bottoming out on my last (2005) Tacoma DC OR 4WD. When I traded in the '05 for the '10, I kept the Ride Rits in case I would need them on the new truck (didn't know about the TSB then)... but the new truck has better springs!
    Photos of the Ride Rites and Bilstein 5100s that were also installed to improve the ride:
  4. Mar 14, 2010 at 3:45 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    When I installed mine I used jack stands to loosen the u bolts - but in all honesty it should matter as either way the weight of the truck is still on the rear suspension and springs. The jack stands will only remove the weight from the tires, which I removed to make access easier, and thus needed the jack stands.;)
    The metal baseplate of the bump stop assembly helps keep the u bolts stationary on the leafs. I don't know what would happen if you ran the truck without them, but I imagine they are there for a reason as the u bolts shifting on the spring would cause wear over time and affect alignment. Just cut off the upper rubber portion, replace the base plate to anchor the u bolts and be done with it.
