Ride Rite schrader valve location
Discussion in 'Towing' started by L J, Feb 16, 2017.
  1. Feb 16, 2017 at 2:49 PM
    L J
    L J [OP] Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Just got a set of Ride Rites in the mail. May be installing this weekend. Where are you guys mounting the schrader valves? Looking for ideas, thanks!
  2. Feb 16, 2017 at 2:54 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Stock rear bumper? There is a hole next to the bolt that hold the bottom of the bumper to the bumper reinforcement bar bracket. Should be pretty close to the right size.
    It is where the silver bolt is next to my quick disconnect.
  3. Feb 18, 2017 at 6:39 PM
    L J
    Illinois
    I'm thinking something out of the weather. Maybe inside the bed cubby on the passenger side. I don't have OBA. I'll be mounting two Schrader valves and two air gauges.
  4. Feb 18, 2017 at 6:46 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Ok. I wasn't thinking with gauges. I was thinking just the two valves, which could be mounted on the bottom of the bumper (has a hole on both sides).
    But remember to put it somewhere that would be accessible if you put stuff in the back and need to fill the bags.
  5. Feb 18, 2017 at 10:06 PM
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    I put mine in the cubby hole next to my power outlet. Fill them before you load the bed.
  6. Feb 19, 2017 at 6:00 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I put mine on the trailer light plate. Have worked well for over 3 years now.
  7. Feb 22, 2017 at 7:30 AM
    L J
    Illinois
    That's a good spot.
    Besides not blocking the door have you had any issues/regrets about using that location?
    I'm still thinking of using the cubby next to the power outlet. I removed the whole box to get a good look at the space and access. Broke off one of the 6 torx screws and bent another but I was able to drill out the broken screw. There is lots of room there and easy access. I plan to mount the gauges at an angle inside the cubby with the schrader valves directly beneath and slightly in front of the gauges so that they are lit by the gauge illumination. I'm planning to tap into the trailer harness for illumination power to the gauges and also will put a dimmer and or switch in line to be able to adjust the brightness or turn them off. I picked up a toyota dimmer switch from the local salvage yard for 5 bucks but haven't been able to figure out the wiring yet. It's a combination dimmer and dome light switch from a camry (wanted that factory look). Also ordered a tubing cutter off ebay for a few bucks to get that clean straight cut that is required for the push-to-connect air fittings in the Ride-Rite kit. I was all set to tackle this last weekend. Then I opened the box from Firestone and it was missing the heat shield and one of the shrader valves. If I get to work on this over the weekend I'll include a few pics.
  8. Feb 23, 2017 at 4:45 AM
    BYBO
    Byron
    Indiana
    I don't really have any complaints about the location. It's not like you can use those cubby holes for anything anyway.
  9. Feb 23, 2017 at 4:51 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I went with the onboard compressor...and I mounted it in the cubby in the bed. IMO, the on board compressor is the best way to go. worth the money all day long
  10. Mar 8, 2017 at 8:50 PM
    L J
    Illinois
    The onboard air compressor is definitely the hot setup. I was really tempted but I'm gonna try it without to see how bad it is. Got the air bags installed but didn't get the gauges plumbed in yet. Was also working on a aux fuse panel. It's done now so I can get back to the gauge install. Here's a pic of the fuse panel.IMG_1804.jpg
    Installed.
  11. Mar 8, 2017 at 8:56 PM
    TerandDi
    TerandDi Member
    2015 White DCSB TRD Sport
    I mounted mine in the rear bumper between the license plate lights and the license plate. Easy to drill through the bumper and accessible whether or not you have anything in the bed. Did it the same way on my 97 Tacoma.
  12. Mar 8, 2017 at 9:08 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    use them on the licence plate as bolts to hold the plate to the bumper
    02Duck likes this.
  13. Mar 10, 2017 at 10:02 AM
    L J
    Illinois
    Thanks. That was my first choice but the problem is I have a license plate frame mounted backup camera and the schrader valves aren't long enough. I have the gauges mounted in the box next to the 110v outlet now and the schrader valves are connected but not mounted. Still looking for a better spot. That box just isn't ideal. It's a little small and I have to sit on the tailgate to reach it. It's operational again and I can monitor the psi at a glance so that's progress.
  14. Mar 10, 2017 at 12:07 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    or you can get the compressor kit and not have to worry about Schrader valves just a thought
  15. Mar 10, 2017 at 12:11 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    No way, it's like $300 more isn't it? I put my bags in and won't touch them until snowmobile season is over and then I'll air them down and not touch them again until next winter. Not only that but you can adjust the air pressure by hand with the smallest bike pump on earth, I keep it in my center console. My valves are locaed underneath the bumper, left of the license plate.
  16. Mar 10, 2017 at 12:19 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I think you can buy the complete kit with bags and compressor for around 500. worth it to me so you don't have to worry about finding a gas station to air up. it's all done in the cab within hands reach
  17. Mar 10, 2017 at 12:23 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    yep. love having mine in the center console. just look down and adjust to the right psi! kinda nice.
    but If I didn't do the compressor, I would have put the valves on either side of the license plate. seems like a good location too!
  18. Mar 10, 2017 at 12:24 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    if any body is looking for a kit I have a complete one and am willing to sell
  19. Mar 10, 2017 at 12:34 PM
    jethro
    Geoff
    Southern NH
    Gas station? You can fill them in 10 seconds with one of these:
  20. Mar 10, 2017 at 2:40 PM
    L J
    Illinois
    I used something like that this morning to adjust them. I like the full kit with compressor and I can afford it but I really don't need it. I got the gauges so I could spot a leak if one happens and fix it at home instead of on the side of the road.
