Ride Rites Installed Last Night!
Discussion in 'Suspension' started by Kale, Apr 12, 2013.
  1. Kale
    Kale [OP] New Member
    Alberta, Canada
    SR5
    Just installed the Firestone Ride Rites Yesterday on my 2013 Double Cab and quite impressed! Easy install, no compressor kit but with only 5-10 psi the ride is firmer and has some "bounce back" from the rear over sharp bumps. I've been through most of the related threads and am wondering if there is any news out there in running them at less than the manufacture min rated pressure @ 5 psi?
    Would like to have the smoother factory ride as much as possible when not towing or hauling a load.
    Thanks.
  2. kavy
    kavy Member
    Shaun
    CALGARY
    2011 Tacoma DC TRD
    3" Lift
    Run them at 5psi, it should feel almost identical to stock at that amount.
