Rides better loaded?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Mar 26, 2012.
  1. Mar 26, 2012 at 8:14 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    I had a bike in the back of the bed this weekend after a while and noticed how smooth the truck rode with the load (~500 lbs) compared to without. I have the TSB leafs and Billies up front and when unloaded, it just bounces around too much compared to how planted and steady it feels loaded.
    Any remedies to help it ride better while unloaded?
  2. Mar 26, 2012 at 8:17 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    Sandbags.
  3. Mar 26, 2012 at 8:28 AM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    What rear shocks do you have? I suspect not matching billies the way you worded that, so matching them up might help a bit. Other than that, its what pickup trucks do, and have always done. Or they put such light springs in at the factory to make the ride "nicer" empty, but can't pack any weight. Then issue a TSB update for those that want to.
    3 leaf non-tsb springs with air bags is the best of both worlds if you don't mind adjusting the air pressure to your load.
  4. Mar 26, 2012 at 8:37 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    i agree .. truck rides much better with a small"ish" load in the back
  5. Mar 26, 2012 at 8:43 AM
    badger
    badger Well-Known Member
    07 SR5
    Yeah, the back ends are very light. Another solution that actually has some additional benefit is a plate bumper. If you have not upgraded yoir shocks in the back, you might consider that. The more spring you have the more dampening you need. I've got a fairly heavy constant load on mine and it handles and rides very well. None of my suspension is stock though.
  6. Mar 26, 2012 at 8:55 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    New shocks help. My truck rides a lot smoother when loaded down also.
  7. Mar 26, 2012 at 8:59 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    the weight of a canopy helps alot.
  8. Mar 26, 2012 at 10:00 AM
    550kawirider
    550kawirider Well-Known Member
    Bryceson
    Visalia, CA
    '09 TRD Sport DC SR5 4X4 - Mag Grey
    Magnaflow Cat-back Exhaust, 2 10'' Image Dynamics IQD.V4, JCV 2DIN, Axxcess Steering Wheel Controller, MB Quart ONXY Component speakers, OME 855 Coils, 5100's Front/Rear, 1/4 Taco Lean spacer Firestone Ride Rite Air bags, GloShift Dual Digital Air Guage/Needle Gauge, LotTek A Pillar Dual Gauge Pod, Powder Coated TRD Sport Rims, Coverking Seat Covers, Custom Interior Lighting, Custom TRD Sport Decals, Tint, In cab power outlet, Fog anytime mod, Backup camera anytime mod, Blue Sea Systems 6 bank fuse block w/ thermal switch, Viper 5901 Security/Remote Start, LED Bed Lights, Blacked out Badges, In-cab air bag controller, 265/70/17 Duratracs, Viair On-board Air System, Grover Semi truck air horn, Rhino Rack over bed rack system
    ^^ This^^ I am running 5100's front (w/ OME 885's) and 5100's in the rear with air bags (Firestone ride rite) with the factory 3 leaf pack. The air bags along with the 5100's soak up the road.
  9. Mar 26, 2012 at 12:54 PM
    xxaarraa
    Do rear 5100s really help? Aren't billies firmer than stock which means theoretically they firm up the ride aka make it harsher?
  10. Mar 26, 2012 at 1:04 PM
    Pugga
    Massachusetts
    More controlled though, less bouncy. OME shocks are supposedly softer riding but I don't know of anyone using them at stock height.
    Part of it is just the nature of driving a pickup truck. They are very light in the rear end and have a solid axle out back so they don't ride as smooth as an independent suspension system. Most people complain that that Tacoma suspension is way too soft so you're kind of unique with your problem.
    There are a few other things you can do but they'll kill the life of your leaf pack. You could remove a leaf or the overload or go with lift shackles. Another option, go back to the non-TSB leaf pack and get airbags or timbrens for when you're loaded. That way you'll ride nice and soft when unloaded.
  11. Mar 26, 2012 at 1:12 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
