Right aftermarket wheel size for my Tacoma.
Discussion in 'Wheels & Tires' started by bordinco90, Feb 1, 2017.
  1. Feb 1, 2017 at 3:34 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Yeah you'll be safe with 8" or 8.5" :thumbsup:
    I work at www.autoanything.com if you happen to see a wheel there that you like let me know and I'll try and get you a deal :cheers: just shoot me a PM
    757yotas likes this.
  2. Feb 1, 2017 at 3:35 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    For example i found my wheels (XD hoss) in a 16x8 with 4.5" backspacing and 0mm offset. Then i went looking for a tire and found a great deal for 265/75r16 BFG KO tires load E for 145$ Each. In the width spec on the tire it said alows for a 7.5-8" wheel width. Got them and they worked perfect.
  3. Feb 1, 2017 at 3:35 PM
    757yotas
    Virginia
    2007 TRD Sport
    Why did i not know this 5 weeks ago haha
    eccracer104[QUOTED] likes this.
  4. Feb 1, 2017 at 5:16 PM
    bordinco90
    bordinco90 [OP] Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    Ok guys one more question... What if I wanted to keep the stock 16 inch steel rims on my truck? What tire size would look more aggressive and make the truck taller with the front leveling lift?
  5. Feb 1, 2017 at 5:16 PM
    bordinco90
    SW Louisiana
  6. Feb 1, 2017 at 5:22 PM
    bordinco90
    SW Louisiana
    265/70/16s?
  7. Feb 1, 2017 at 5:55 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Well you know now :laugh:
    265/75-16 is the largest without issue.
    265/70-16 is stock for trd models, and you can go up one size from that. I take it you have 245 tires now?
  8. Feb 1, 2017 at 5:56 PM
    bordinco90
    SW Louisiana
    Yes the 245s is what is on my truck now. The stock size. Looks kinda cheesy with the small tires.
  9. Feb 1, 2017 at 6:03 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Lol. Yeah it'll look a lot better with the bigger tires :thumbsup:
  10. Feb 1, 2017 at 6:29 PM
    757yotas
    Virginia
    2007 TRD Sport
    Try googling pis of the 265/70 on your truck stock and see what you think. The 265/75 may rub some but not 100% sure
  11. Feb 1, 2017 at 6:44 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    265/70-16 matches factory on the TRD models. The base model has the same ride height, just looks so much smaller because the 245 tires. 265/70-16 will fit as is. 265/75-16 will also fit as is, but looks perfect paired with a ~1" lift up front to help level the truck out. No rubbing issues.
    Googling some pictures or searching the forum for pictures is a great idea though.
  12. Feb 1, 2017 at 9:04 PM
    bordinco90
    SW Louisiana
    Yeah I checked it out and it should look awsome. I just thought "why get the rims, when it will look good with bigger tires..."
  13. Feb 1, 2017 at 9:05 PM
    bordinco90
    SW Louisiana
    I'm most likely going to get the Kumho Road Venture AT51.
  14. Feb 1, 2017 at 9:14 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Both 265/75-16 (32" dia) and 255/85-16 (33" dia) will fit. 255/85-16 looks taller but is more limited in selection (only 2-3 tire choices, in heavy load range E); you will also start to see some minor power loss from the 8% taller gearing.
  15. Feb 11, 2017 at 7:29 PM
    #35
    Buckaroo1993
    Buckaroo1993 Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    @757yotas ... Do you have a lift/level on your Taco?
  16. Feb 11, 2017 at 8:01 PM
    #36
    757yotas
    Virginia
    2007 TRD Sport
    Yes, i have OME 881s with 5100 shocks up front along with a 3/8" spacer on the drivers side for lean. The rear is lifted with OME Dakar leaf packs.
    Buck18 likes this.
  17. Feb 11, 2017 at 8:40 PM
    #37
    Buckaroo1993
    Vinny
    Georgia
    @757yotas Finally! Someone who has what I am looking at getting! I have a 2003 DBLC 4wd TRD/SR5. I want to ask a few questions:
    1) I plan on installing an ARB bumper w/winch (maybe not immediately but soon). Will the 881's suffice or should I get the 882's? (I will be using the OME Nitrocharger front and rear shocks instead of the 5100's)
    2) I have purchased 16x8 alloy rims/0 offset/4.5 bs. What tire size are you running?
  18. Feb 11, 2017 at 9:13 PM
    #38
    757yotas
    Virginia
    2007 TRD Sport
    1) The 881s will ride better and look like you want with the stock bumper (or light tube bumper), but the ARB is heavy so if you plan on getting on plus a winch i would get the 883s. The 883s provide the same lift as 881s but have more spring rate so it will be a harsher ride at first but will ride nice once that new bumper goes on. 882s are going to give you to most lift but if you like the look of 881s then 883s are your best bet. If i was you id get 883s and deal with the harsher ride for alittle till i got the bumper.
    2) i run LT265/75r16 BFG KO tires. Its a great looking tire for the lift and needs no trimming required. Great for offroad aswell as you have more flex room.
    Buck18 likes this.
  19. Feb 11, 2017 at 9:24 PM
    #39
    Buckaroo1993
    Vinny
    Georgia
    What about new uca's? Do I need them?
  20. Feb 11, 2017 at 9:25 PM
    #40
    757yotas
    Virginia
    2007 TRD Sport
    No the stock work fine
