Right fit for roof rack on AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STLegend, Jan 21, 2018.
  1. Jan 21, 2018 at 1:15 PM
    STLegend
    STLegend [OP] Well-Known Member
    '13 TRD OR
    OME, DX4, S/T Maxx, Bushwackers, A.R.E Shell, Yakima Racks
  2. Jan 21, 2018 at 1:44 PM
    Pigpen
    Dan
    Northwest Montana
    Those Q towers need the right clips to fit the Tacoma. Otherwise it can be adjusted to fit. I have a Yakima Q tower rack.
    Problem is, Yakima doesn't offer the Q towers or the clips anymore.
  3. Jan 21, 2018 at 1:50 PM
    Dcwn.45
    Dcwn.45 Well-Known Member
    David
    2013 dcsb trd off road
    OME suspension ARB front bumper Warn M8000
    I have Yakima racks on my truck
    But they are newer towers and clips
    Better than the old style, better weight rating.
    The bars and fairing and any bar mount accessory will work, but you would have to buy new towers and clips
  4. Jan 21, 2018 at 2:15 PM
    STLegend
    '13 TRD OR
    Thanks! bummer to hear about Yakima not selling the clips, I guess it keeps you buying new...
  5. Jan 21, 2018 at 2:32 PM
    STLegend
    '13 TRD OR
    Looks like they may still be for sale: https://www.yakima.com/q-clips
    Also with Yakima selling naked towers with no clips it leads me to believe I can mix and match clips to fit the vehicle and the tower is universal.
    FYI it is Q127 for the front and Q128 for the back (that's for an AC)
