right front turn signal does not work
Discussion in '1st Gen. Tacomas (1995-2004)' started by retsamsiadoy, Nov 21, 2017.
  1. Nov 21, 2017 at 12:13 PM
    retsamsiadoy
    retsamsiadoy [OP] Member
    2001 toyaota tacoma 4wd 6 cylinder 3.4L
    So my 2001 tacoma right front signal does not work. the right rear works but blinks fast and the left side is fine. I changed the bulb with no change in function. I bought a new relay because it was cheap and thought it couldnt hurt. I am not sure where to find the relay on my truck. Not really sure where to go from here to figure this out.
  2. Nov 21, 2017 at 12:17 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is there power to the front turn signal? It may just not be getting a good contact and or burned/melted contact.
  3. Nov 21, 2017 at 2:46 PM
    retsamsiadoy
    all the contacts look good
  4. Nov 23, 2017 at 2:26 PM
    Glamisman
    Glamisman Well-Known Member
    replace the bulb with the other sides bulb or a known good one. The fast flashing is an indication of insuffient resistance in the wiring due to a bulb not working.
  5. Nov 24, 2017 at 2:05 AM
    doyouquaxu
    doyouquaxu Well-Known Member
    Mine does the same thing, haven't looked into the issue much yet. Post back if you figure it out.
  6. Nov 24, 2017 at 3:11 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Clean the socket things do tend to corrode
    If the rear flashes it is not the flasher .
  7. Nov 26, 2017 at 9:50 AM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Sounds like you have a short on the front wire. That causes the flasher relay to heat up really fast and gives you the very fast flash for the rear bulb. Start checking the wire harness from the front bulb on back.
    wilcam47 likes this.
  8. Nov 26, 2017 at 6:34 PM
    wilcam47
    Will
    Bourbon state
    could also be cut wire, since the front bulb isnt drawing any volts its causing the rear to flash quicker..
