Right headlight blowing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patriot0331, Jan 26, 2023.
  1. Jan 26, 2023 at 11:13 AM
    patriot0331
    patriot0331 [OP] Member
    2012 Toyota Tacoma TSS
    So my right passenger headlight keeps blowing out. I checked the fuses and they are all good, traced the wire and nothing seems to be cracked.......anthing else I am over looking?? Frusterating, Emotional Damage!!!
    HondaGM likes this.
  2. Jan 26, 2023 at 11:17 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Are you sure the connections at the bulb are tight?...
    what kind of bulb are you using...are you touching the bulb?
    davidstacoma likes this.
  3. Jan 26, 2023 at 11:19 AM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Check for loose connector terminals. This could cause resistance issue or volt drop issue causing your concern. You should actually preform a amperage test across the crt with a know good bulb. Compare LH to RH amps. this would verify the complete crt is OK.
    HondaGM likes this.
  4. Jan 26, 2023 at 11:25 AM
    patriot0331
    OK, thats a good suggestion, I will give that a shot tonight after work. Man im working so hard right now at work seeking answers on Tacomaworld!!! hahahaha The connection is solid when plugged in and the bulb is locked in place with the sping lock. I'm using the standard 9003 bulbs from Napa
    HondaGM likes this.
  5. Jan 26, 2023 at 11:48 AM
    Scott W
    Scott
    Saranac Lake, NY
    Make sure the bulbs are clean. Any fluid including your figures touching them can affect bulb life. Clean them with alchohol. Dry gas works good or like.
    HondaGM likes this.
  6. Jan 26, 2023 at 12:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you using Sylvania SilverStars?
    If so, they have a reputation for not lasting long in these trucks.
    @crashnburn80 can probably tell you what bulb he recommends.
    HondaGM likes this.
  7. Jan 26, 2023 at 12:23 PM
    patriot0331
    Yes, thats exactly what i'm using. Thats all our local Napa has though
    TnShooter[QUOTED] likes this.
  8. Jan 26, 2023 at 3:38 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Sylvania Silverstars have a very short life and are typically not a good bulb for performance. They have had class action lawsuits over short bulb life and false performance claims. They give you whiter light, but not necessarily that much better. Unfortunately Sylvania has somewhat of a monopoly on the US autoparts stores, so local options are usually only them.
    Keep in mind, any performance bulb is going to have a shorter life than a standard bulb, it is the tax paid for the extra performance.
    I'd recommend Philips Racing Vision +200s. They will have great low beam improvement and reasonable life. The Silverstars are rated at 150 hours, the Racing Visions at 400 hours, which is exceptionally good for their performance level, which will be much better than Sylvania's. The Racing Visions due have a blue coating over the high beam, like Sylvania, so there is some reduction in high beam output vs stock.
    https://www.amazon.com/Philips-Raci...00&qid=1674775863&s=automotive&sr=1-1-catcorr
    TnShooter likes this.
  9. Jan 26, 2023 at 3:46 PM
    TnShooter
    Deogee
    STOCK
    Thanks.
    I knew you’d know more about this:thumbsup:
    crashnburn80[QUOTED] likes this.
