Right pull and vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wojotiger, Mar 24, 2020.
  1. Mar 24, 2020 at 9:01 PM
    Wojotiger
    Wojotiger [OP] Member
    I have a decent right pull and light vibration between 45 and 60mph. It's a 2014 dbsb 4.0 4x4 on wildpeak at3 285/75/16 with 3inch bilstien 5100s all around, ome coils and an add a leaf in the rear. The shop has aligned it multiple times and state its aligned properly but still pulls more than I would like. I asked about getting new ucas for more adjustment room but told it wasn't necessary. Thoughts?
    Second issue with vibration, could it be the needle bearing?
  2. Mar 25, 2020 at 5:43 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Pull could be a few things, tire pressures? road camber? brake pull?
    I have to say that after multiple alignments i really hope they did not miss anything loose/broken/failing/out of wack on the front end.
    Vibration, balance, bad tire.
  3. Mar 25, 2020 at 5:44 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Maybe try rotating the tires around and see if anything changes.
    jetfishn likes this.
  4. Mar 25, 2020 at 4:27 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Do this^^^^ if you swap the two front tires side to side and the pull stays the same it’s not the tires.. if it pulls left it’s the tires.
    Muddinfun and ryfox0276[QUOTED] like this.
