Right Rear Bottom Shock Mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pony Express, Oct 29, 2023.
  1. Oct 29, 2023 at 5:37 AM
    Pony Express
    Pony Express [OP] New Member
    Peter
    Red Tecoma 96 4X4
    The bottom mount for the right rear shock corroded and has broken off.
    1. Can the plate below the axel be replaced?
    2. If so, what is its name, where and can it be purchased?
    3. Also, do the U-bolts need to be replaced?
    Thank you.
  2. Oct 29, 2023 at 5:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    If that's happened I'd be very concerned about the safety of the rest of the frame.
    If you will post some pictures it would help.
    Sometimes the frame is so far gone it's not worth spending anything to try to fix a part that breaks. Hope that's not your case. Don't be this guy.
  3. Oct 29, 2023 at 6:06 AM
    Rusty Taco 11
    Rusty Taco 11 Well-Known Member
    Xenia Ohio
    2000 Tacoma PreRunner V6 extended cab
    1 Yes.
    2 leaf spring plate rear.
    Toyota 48046-35210
    they usually sell for around $60-$70 new any of the online Toyota dealerships or your local one should be able to get it.
    3 you should replace the U bolts.
  4. Oct 29, 2023 at 6:18 AM
    02hilux
    Planet: EARTH
    Tour991 likes this.
  5. Oct 29, 2023 at 6:19 AM
    02hilux
    Planet: EARTH
    1. Yes
    2. Toyota 48046-35210
    3. I would
  6. Oct 29, 2023 at 12:41 PM
    1997tacomav6
    Denver
    I replaced that part and just removed the nuts and put it on, didn’t replace the u bolts and that was 8 years ago.
    Easy job,
    Your choice if they are rusty then replace U bolts too
