Right Side Speakers Very Faint
Discussion in 'Audio & Video' started by Irishblessing, Dec 8, 2024.
  1. Dec 8, 2024 at 9:47 AM
    Irishblessing
    Irishblessing [OP] So Cal Is Where My Mind States
    2023 Tacoma OR
    I have an issue where all three speakers on the right side of the truck are very faint. When I fade over to each individually all 3 are working.
    I pulled the head unit and reconnected everything in the back after i was driving around a corner and everything came back momentarily but went back out on another tight corner, which led me to believe a loose connection.
    I have looked around a couple of threads and found a suggestion to disconnect the battery for 30 min then reconnect and that does work until i shut the truck off and come back in a couple days to the same issue.
    I have a stock head unit on a 23 model, aftermarket kicker Cs speakers wired with the aftermarket harnesses kits-nothing spliced-I have had everything in for more than a year and a half.
    Is this possibly a common issue with the head unit? Do these not last very long?
    Or Battery? The truck just turned 2 years, which is a little less than what you usually get with a battery-but it is stock. Any suggestions?
  2. Dec 8, 2024 at 10:54 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    When you installed the speakers, how did you connect the wires to the speaker terminals? Did you use the little spade connectors, or attach them more permanently?
  3. Dec 8, 2024 at 11:15 AM
    Irishblessing
    2023 Tacoma OR
    They are attached to the spades.
  4. Dec 8, 2024 at 11:53 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I would pull the door panels and check those connections. Check the terminals on the speakers, and check the connections inside the plastic connectors. Sometimes there can be corrosion inside the connector that causes issues.
    also, there’s a chance it’s internal in the radio itself. That one isn’t any fun because there’s not really any repairing it.
  5. Dec 8, 2024 at 12:09 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    True, but at least OP is still under warranty there
  6. Dec 8, 2024 at 12:16 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Problem is, they will blame his aftermarket speakers, blame his install, blame anything they can.
    OP, do you still have the factory speakers? If so, pop them back in and see if the problem persists
    soundman98 likes this.
  7. Dec 8, 2024 at 12:19 PM
    ABA180
    East Bridgewater MA
    Not a bad idea if possible. I surmise it's a head unit or wiring issue..question is, how much did OP change re wiring
  8. Dec 8, 2024 at 1:23 PM
    Irishblessing
    2023 Tacoma OR
    I am leaning toward a HU.
    1. Becuase it's the entire right side and not the individual speakers themselves.
    2. I was able to reset the fault, and a random corner brought the speakers back into play.
    Unfortunately my truck is now outside of warranty. I was hoping to put this off but i just bought an aftermarket HU, the Sony XAV-9000ES.
    I will update after i install. Thank you for the help
