Right turn signal constant on tow connection
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jaxarmy1776, Mar 23, 2025.
  1. Mar 23, 2025 at 5:31 PM
    Jaxarmy1776
    Jaxarmy1776 [OP] Member
    2016 tacoma off road
    Hello all
    So getting the boat ready to go out and hooked the connection to my truck but the turn signals on the truck stop working with the trailer connected. Come to find that there is constant power at the right turn signal pin on the connector from the truck. Brake lights and markers work fine. Soon as I use a turn signal it stops working on my truck until I disconnect the trailer. Btw Trailer is completely rewired all new lights and such. But the issue is on the truck side connection
  2. Mar 23, 2025 at 5:53 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    Sounds like the trailer might be wired wrong.
    stealthmode likes this.
  3. Mar 24, 2025 at 9:09 AM
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
  4. Mar 24, 2025 at 9:27 AM
    Jaxarmy1776
    I thought so hence why I rewired the whole trailer. What I found after it still didnt work right was the right turn signal pin coming from the truck has constant power.
  5. Mar 24, 2025 at 9:32 AM
    Midnight beauty
    White mountains AZ
    Did you check the left turn signal to see if it had power all the time also. If you have a constant power for the right turn signal at the plug then your right turn signal should be on solid. Unless Toyota uses a ground system to control the circuit.
  6. Mar 24, 2025 at 9:34 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    I think the pin directly across from the RT always has power.
    Is it possible the connector has been altered, or your trailer is backwards?
  7. Mar 24, 2025 at 9:34 AM
    Midnight beauty
    White mountains AZ
    I would unplug the 7way connector on the truck and test the pins at the connector to the plug and see if you still have constant power at that pin.
    Jaxarmy1776[OP] and BillF1564 like this.
  8. Mar 24, 2025 at 9:37 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Are you using the 7-pin or the 4-pin? If you turn on the blinker of the truck, does the power start to pulse or still stay on? What wires are you probing to check for turn signals?
  9. Mar 24, 2025 at 10:19 AM
    Taco_Ventures
    N
    SL, UT
    23 Taco OR DCLB
    7 pin uses the same pin for brake and turn.
  10. Mar 24, 2025 at 1:32 PM
    Jaxarmy1776
    Tested the left turn signal at the truck side connector and its working as intended only when the left blinker is on.
    Checked both 7 pin and 4 pin. Right turn is constant on both.
    Inspected both connections and they look original with toyota logos on the trailer output connectors.
  11. Mar 24, 2025 at 1:34 PM
    Jaxarmy1776
    Wondering if one of the relays is stuck or shorted open its only affecting the trailer connector. So when I plug the trailer up it backfeeds and kills my truck turn signals. Guess I can check all the trailer related relays under the hood for being open.
    Will also disconnect the 7 and 4 pin since its doing it on both maybe a ground issue
  12. Mar 24, 2025 at 1:38 PM
    airforceb2cc
    Don
    KCMO
    If there is constant hot to the pin without the trailer connected, you have a wiring problem. Stock tail lights?
  13. Mar 24, 2025 at 4:42 PM
    Jaxarmy1776
    Yes still stock
  14. Mar 24, 2025 at 5:36 PM
    airforceb2cc
    Don
    KCMO
    I would check to see if the 12V constant is shorting out to the turn signal wire.
  15. Mar 24, 2025 at 5:46 PM
    Midnight beauty
    White mountains AZ
    It sounds like it might be shorted in the 7 way to 4 way. If you checked the plug that goes into it and it works right and then you plug it back into the 7way it gets power to the turn signal constant
  16. Mar 24, 2025 at 7:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pull your TOWING Fuse (25A) and see if the power goes away at the trailer connector, if it does then the issue is most likely the Combination Meter (Instrument Cluster).
    For some reason Toyota chose to have the Meter run the trailer lights on the 3rd and 4th gen trucks and a short in the trailer will wreck the circuit in it.
    I would advise anyone with a 3rd gen to replace the TOWING fuse with a 10 or 15 amp so it will hopefully blow the fuse instead of fry the Meter if a trailer short occurs.
    eurowner likes this.
  17. Mar 24, 2025 at 7:55 PM
    Jaxarmy1776
    I appreciate everyones input I will check the connector and pull the fuze and check it tomorrow!
  18. Mar 25, 2025 at 5:36 AM
    Midnight beauty
    White mountains AZ
    I hope that works for you.
  19. Mar 26, 2025 at 1:20 PM
    Jaxarmy1776
    So yeah still power with towing fuse out.
  20. Mar 26, 2025 at 1:40 PM
    Midnight beauty
    White mountains AZ
    Try unplugging the headlight multifunction switch and then check to see if you still have constant power.
