Rigid 30 inch bar mounts
Discussion in 'Lighting' started by MAKAIRA, Oct 10, 2021.
  1. Oct 10, 2021 at 9:09 PM
    MAKAIRA
    MAKAIRA [OP] Well-Known Member
    Tim
    Looking to mount the 30 inch Rigid light bar and the question is-
    Hesitant in using their brackets and cutting the plastic on lower grill.Has anyone used any other mounts such as the Diode Dynamics or Caliraised with the Rigid bar?
    Thanks
  2. Oct 16, 2021 at 3:28 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Brackets are pretty generic. CaliRaised should work fine, people have used them with the Diode Dynamics bar.
  3. Oct 18, 2021 at 8:13 PM
    MAKAIRA
    Tim
    Thanks-looks like the DD brackets will work.Thanks for the help with all the advice on the lighting
    crashnburn80 likes this.
  4. Oct 19, 2021 at 11:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Because I was recently looking at this for something else, I thought this would be fun to share here. This is a used several year old Rigid combo bar vs an AuxBeam combo bar. Output intensity is captured in the Lux value. People often think getting some cheap china bar is the same as a name brand product, but it isn't even close.
    Tacomod likes this.
  5. Oct 20, 2021 at 8:21 PM
    MAKAIRA
    Tim
    Wow couple of those numbers are huge,
    Gotta say the install has been somewhat a pia but got it pretty much done.
    Anyone looking for some rigid mounts?
    I went with the Rigid bar as the price was better then what I origanally thought.
    Again thanks for the info you provided here.
