Rigid Dually Flush Mount Backup Lights
Discussion in 'Lighting' started by satmanski, Aug 5, 2012.
  1. Aug 5, 2012 at 3:38 PM
    satmanski
    satmanski [OP] 12yrs 170k
    Sean
    Santa Fe, NM
    2011 4dr TRD
    Avid Offroad Light Bar, Rigid 10" E2 and SRQ backup lights, Weathertech Floor mats, GrillCraft Insert, tinted windows, DebadgeD, Yakima Bike carrier inserts, afe pro dry air filter, Seat belt chime defeat
    Tinted windows and rocky trails don't mix. I have looked all over the back for mounting options and think this will be the safest (least likely to be wiped smooth by rocks). My trailer connector is testament to bottoming out. Still there but the mounting plate is not long for this world. I don't think it looks too bad. The lights I'm planning on using are the rigid dually wide beam. Not sure of the regular or D2 flavor. One is 1300 lumens and the D2 is 2600 and twice the price. Any opinion on looks?
  2. Aug 5, 2012 at 3:48 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    D2 all the way!
  3. Aug 5, 2012 at 4:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think it looks fine and if it's fuctional, thumbs up for probably the most expensive backup lights ever :laughing:
    Silverspool likes this.
  4. Aug 5, 2012 at 8:03 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Dually... D2 would be a little overkill for backup lights.
  5. Aug 6, 2012 at 6:29 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Go for the regular duallys....for back up lights that should be PLENTY!!
  6. Aug 6, 2012 at 6:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I spent less then $75 on my back up LED lights. Can't beat trucker lights.
    If I were you, you should wire them to a separate switch. You will blind people under normal parking lot conditions with the ones you want.
  7. Aug 6, 2012 at 6:39 AM
    LocoTaco
    LocoTaco Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    Cool! I like them.
  8. Aug 6, 2012 at 12:47 PM
    satmanski
    Sean
    Santa Fe, NM
    2011 4dr TRD
    Thanks for the replies. After more research the D2's would be rear facing terrorists to all those around. The regular dually's with the diffuse lens would do the trick just fine. But yea its all kind of expensive just for back up lights. Thats what girlfriends are for right? :D
  9. Aug 6, 2012 at 12:50 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    x2. would like to see some in a plate bumper tho.
    aslo i like the look of them in the stock bumper.
  10. Aug 12, 2012 at 11:48 PM
    RigidIndustries
    RigidIndustries Built To Be Seen
    Gilbert, AZ
    Looks awesome. I must say the New D2/Dually flush mount kits are so easy to install and look very clean.
    Thanks for supporting Rigid Industries and an American Made company.
  11. Aug 12, 2012 at 11:52 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    welcome rigid industries! :wave:
  12. Aug 13, 2012 at 12:03 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Second that! The Halo is the best flashlight I have ever owned!
  13. Sep 4, 2013 at 4:39 PM
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    Those look great!!!
  14. Sep 4, 2013 at 5:49 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    I would say the original dually would be more then enough light for back up use, especially in a pair.
  15. Jun 21, 2014 at 3:59 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    any updates here? i am looking for a rear light set up for my taco
    thanks J
  16. Jun 23, 2014 at 10:34 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  17. Jun 23, 2014 at 10:43 AM
    Large
    Large Red
    I'm running the diffused flush mount d2s in my rear tube bumper, tied in with my reverse lights. Works like a charm
  18. Jun 24, 2014 at 2:37 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Rigid has a new reverse light harness kit out that pretty much allows you to wire up and light cleanly as a reverse or work light. It includes a tow package wire tap for easy reverse use.
  19. Aug 31, 2016 at 7:10 PM
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    OP, how did you get the D2's to point in the right direction with the flush mounts? Any issues with aiming the lights?
  20. Sep 2, 2016 at 3:43 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    You brought back a really old thread....
    I can't speak for the original poster but I did mount mine in a stock bumper. There is no real aiming that can be done with flush mounts without tweaking the bumper physically. Space is limited as to where you can mount them due to the stock hitch. The bumper itself has a slight angle to it. Lights installed will project down slightly. To me, this worked perfectly. It doesn't blind anyone directly behind you. I had the D2 w/diffused lens. There was one gentleman on here that modified the stock bumper so the lights were completely level. It involved welding an such.
