Rigid Duallys Wiring
Discussion in 'Lighting' started by tgriff, Dec 3, 2015.
  1. Dec 3, 2015 at 6:48 PM
    tgriff
    tgriff [OP] Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    Just ordered some dually LEDs by Rigid Industries to use as aux reverse lights. I know that there has to be a thread on this somewhere but I had no luck with a search. If someone could direct me to a helpful thread specific to this application I would appreciate it. If anyone has any pictures of this setup or helpful tips that would be great too!
  2. Dec 3, 2015 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Jerez and PSU Taco85 like this.
  3. Dec 3, 2015 at 6:54 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Do you want them independent or to come on with your backup lights?
  4. Dec 3, 2015 at 7:00 PM
    tgriff
    Tim
    CT
    I was going to have them independent so I can switch them on whenever I want. This means I dont need a relay right?
  5. Dec 3, 2015 at 7:05 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    If the wiring kit had one, you need it.
  6. Dec 3, 2015 at 7:06 PM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    You still need to use a relay
  7. Dec 3, 2015 at 7:15 PM
    tgriff
    Tim
    CT
    I'll have to see when it gets here but according to the website the kit just includes a wiring harness and switch. What purpose does the relay serve if the lights are on an independent switch?
  8. Dec 3, 2015 at 10:32 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    The relay is used to power lights that draw more current than the switch can handle. Typically switches are less than 20 amps.
  9. Dec 3, 2015 at 10:39 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Dually's pull under 10 amps I think so a relay isn't really necessary but it is still a good thing to have. The wiring harness they come with has one built in I think.
    PSU Taco85 likes this.
  10. Dec 3, 2015 at 10:47 PM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Here's the way I wired mine for an 'on anytime' and turn on automatically when shifted into reverse:
    175CEF09-8A18-41F5-80F7-70494125C667_zps_1af3ebb8987fc779e1c68ca3e6c219190dbab53e.jpg
    The wire labeled 'from backup light switch' is the factory reverse light wire.
    taczilla likes this.
  11. Dec 11, 2015 at 3:53 PM
    tgriff
    Tim
    CT
    Thanks for the comments guys..turns out the wiring harness included an in-line fuse. Just had to connect to the battery, run the switch into the cab, and route the wire to the back of the truck.
  12. Jan 19, 2016 at 8:28 PM
    toolmandoo
    toolmandoo "Crescent Fresh"
    Jeremy
    Orlando
    2015 TRD Sport
    S.O.S bolt-on sliders, XB Morimoto fogs, bumper mounted 20" led bar, amber leds in grille("raptor" style) and Relentless fab hi-lift mount. Plastidip?
    What path did you follow when routing the wiring from the engine bay to the rear lights?
  13. Jan 19, 2016 at 9:29 PM
    At The Helm
    Morgan
    Gardnerville, NV
    Me? I went through the firewall grommet, stored the relay behind the panel next to the clutch, ran wire under the door sill panel, through another existing grommet next to the driver seat going under the truck, then loomed it and went above/inside/next to the frame as high and clean as I could. It gets a little tight and hard to feed around the gas tank area.
  14. Jan 20, 2016 at 9:36 PM
    toolmandoo
    Jeremy
    Orlando
    2015 TRD Sport
    Cool, thank you. Just trying to figure out the easiest path to run wiring to dual rear floods
  15. Jan 30, 2016 at 8:40 AM
    tgriff
    Tim
    CT
    I also went through the firewall grommet to get the switch into the cab. Then went out through the engine bay and to the back bumper by following the factory harness that runs under the truck. I zip-tied the wires for the Rigids to the factory harness.
  16. Feb 5, 2016 at 9:35 PM
    07amocat
    07amocat Well-Known Member
    Colorado
    2007 Silver Tacoma TRD Off Road
    This is how I was going to wire up my reverse lights also. One question though. Why do you need the diode for a lighted switch? I could see a diode between the splice and factory reverse lights if you don't want the factory lights to come if you're using your aux lights as area lights.
    At The Helm[QUOTED] likes this.
  17. Feb 5, 2016 at 9:53 PM
    At The Helm
    Morgan
    Gardnerville, NV
    I actually didn't use a diode, I'm not sure why that's in there (pulled that diagram from another website). It's been working great!
  18. Feb 5, 2016 at 10:05 PM
    07amocat
    Colorado
    That's good news. I was just going to unplug the factory lights and run the factory wiring to the duallys, but I want a switch to use them as scene lights also.
