Rigid fogs vs Off Road oem fogs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lou430, Jul 22, 2016.
  1. Jul 22, 2016 at 12:56 PM
    Lou430
    Lou430 [OP] Well-Known Member
    2016 trd off road
    Yes kit comes with switch, relay and all necessary stuff to make them work on their own. I just wanted them to come on automatically with headlights and stuff
    0311K1LL[QUOTED] likes this.
  2. Jul 22, 2016 at 1:11 PM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    Are the off road fogs different than any of the others? How are the fogs versus the sport fogs or SR5 fogs?
    Tyler
  3. Jul 22, 2016 at 1:15 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Since when are fog lights a replacement for headlights? I think you're missing the point.
  4. Jul 22, 2016 at 1:27 PM
    Lou430
    2016 trd off road
    I asked all the questions before purchasing to rigid. This kit give double the light output of the 2017 trd pro rigid oem fogs. Those are the ones i originally wanted but i wouldnt sacrifice light output
  5. Jul 22, 2016 at 1:28 PM
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    Coming from a rally perspectic and the "wide angle" fogs the trd model comes with reenforces this, fog lights are meant to shoot wide so you can see where you are turning into. And my sports fogs do just that. Driving slowly at night trying to place my wheels precisely, the first 10 feet on front of my truck are black. Turn the wide angle fogs on and its all lit up. Doesnt need to be super bright but they light all of the ground directly in front of the truck and the angle looks to be close to 170 degrees wide.
    They are the first factory fog lights ive had that actually do what they are supposed to.
    If i want to reach far out, i use my light bar.
    Kenjiro and brich999[QUOTED] like this.
  6. Jul 22, 2016 at 1:29 PM
    Lou430
    2016 trd off road
    The sr fogs are only 17 watts and trd models and limited fogs are 55 watts. These rigid are 20 watts but more light output than stock 55 watt fogs.
    Danielnc06 likes this.
  7. Jul 22, 2016 at 1:32 PM
    digitaLbraVo
    No they aren't.
    Fog lights are designed to throw light low and yellow to reduce glare in foggy conditions. The fact the fog lights only work with low-beam headlights makes them more akin to a "driving" or "auxiliary" light, especially how you're describing them.
    Fog lights help you see in the fog by not causing glare which bright headlights that are high up cause.
    Danielnc06[QUOTED] and brich999 like this.
  8. Jul 22, 2016 at 1:46 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    didnt mean to come off rough, this is why i was asking what purpose op needed super bright fog for. these are bright lights im sure, just have a difficult time calling a 6k led that does not light the ground infront or to side of vehicle a "fog" light and have issues with people running dittch lights, light bars, non adjusted 55w hids etc just cruising around on the road.
  9. Jul 22, 2016 at 2:10 PM
    Lou430
    2016 trd off road
    I wanted fog lights but brighter than stock and led so no light bulb replacement hassles.
    I didnt want or need headlight replacement. These are bright enough to drive around town by themselves.
    I will say the off road oem fogs are very good for a halogen light....im not sure sr or sr5 trims use he same.
  10. Jul 22, 2016 at 2:26 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    Good to know! Thank you!
  11. Jul 22, 2016 at 2:54 PM
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    Does the rigid harness and relay power the lights, or does the stock wiring power the lights
  12. Jul 22, 2016 at 3:08 PM
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    You can wire it either way. The harness that comes with it will power it separately or you can get the adapter and they'll work off the factory harness.
  13. Jul 22, 2016 at 3:31 PM
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    I agree, the factory trd fog lights are surprisingly good.
    Bean&Cheese likes this.
  14. Jul 22, 2016 at 4:39 PM
    Danielnc06
    NC
    2016 TRD DCLB
    Yeah you are correct per the name...i have never had them help in a fog though...
    But the fact that the sr5 gets standard foglightts and trds get wide angles lend me to think their purpose is for up front visibility.
    True fog lights are yellow light as you mentioned. And yellows focal length actually focuses on your retina while reducing glare. White and blue focuses before and after your retina. I dont think working, true fog lights have been implemented in factory cars in a while excpet maybe in the luxury level.
    I did second guess argueing the meaning of fog lights when their name implies fog. I guess i was going more towards the intended purpose of these lights because. 2.5 ft off the ground isnt going to cut under any fog anyway.
  15. Jul 22, 2016 at 4:43 PM
    #35
    Danielnc06
    NC
    2016 TRD DCLB
    Yes i bought an hid kit for my wrxs halogen PROJECTORS, still hated the cutoff and sent them back. I now have a special hatred for trucks running hids in reflector housings blinding everyone..
    jonnyozero3 likes this.
  16. Jul 22, 2016 at 4:46 PM
    #36
    Danielnc06
    NC
    2016 TRD DCLB
    Not to thread jack though,
    OP. Lights look good. Ive thought about changing mine out to match the led running lights but i actually prefer the warmth of the halogen bulbs at night during use. Guess im a wierdo!
  17. Jul 22, 2016 at 6:11 PM
    #37
    Lou430
    2016 trd off road
    I agree thats why i keep the stock halogens
  18. Jul 22, 2016 at 9:27 PM
    #38
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    I ended up calling Rigid and the lights come with a harness that is plug n play. Hook it up to the battery and mount the switch and you're good to go. Everything is integrated and already wired.
  19. Jul 22, 2016 at 9:40 PM
    #39
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    For those wanting a pattern closer to the stock trd or fog, but brighter, Baja designs squadron with wide cornering, aimed down about 5 degrees, is fantastic. Keeps a lot of light low, spreads plenty left and right to SEE ROAD MARKINGS (a primary need for fog lights imo), but still projects some down the road for driving.
    IMO, fog lights are meant to replace headlights for driving in fog/dust/inclement weather, where you should be slowing down significantly anyways, so a lack of down-the-road projection isn't a problem. The scientist in my says that people who notice a difference in glare between yellow/selective-yellow and white light are only fooling themselves,so mine are bright white.
    Just thought I'd give folks another perspective.
    JonWon and Baja Designs like this.
  20. Jul 23, 2016 at 9:27 AM
    #40
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    This thread is fail without night output shots
