Rigid light build
Discussion in 'Lighting' started by masterwacker, Nov 25, 2012.
  1. Nov 25, 2012 at 6:28 PM
    masterwacker
    masterwacker [OP] Well-Known Member
    Paul
    Orlando
    2010 Tacoma TRD Off Road
    TRD Sport hood, TRD Sport paint matched rear bumper and grill, BDF grill light bracket with some Rigids, 40" Rigid roof bar, SPOD, Stereo, Pro Comp Prorunner front strut lift and rear shocks, PXA 7036 Wheels-285/70R17 BFG AT/KOs and some other stuff
    I posted a couple pictures of the Rigid lights that I have on my truck and a lot of you wanted to see how I did it, so here it is...
    I purchased a 40" Rigid E-series light bar to mount on top of my truck. The 40" is almost a perfect fit between the factory roof rack rails and I wanted it to sit down almost on the roof.
    So I cut out some brackets
    All I had was some scrap 4" wide steel and I did not feel like buying a new sheet so that is why the brackets don't perfectly follow the profile of the factory roof rack rails. I then used a hole saw to cut out the hole for the tubing that would actually hold the light bar
    Next was to cut out the end caps for the tubing. I changed out the drill bit in the hole saw to match the diameter of the Rigid stud so that way the stud would slid through the pilot hole and I could stick a socket down the tubing to tighten the nut on the Rigid light stud
    Ready to weld the cap on the tubing
    Cap welded on the tubing
    Caps welded on the tubing on both sides and test fit to make sure the bracket holes would line up. That is why I welded the caps on both sides of a piece of tubing even thought the actual piece of tubing would be much smaller.
    Now it was time to fasten the main bracket to the factory roof rack rails. I removed the rails and put them on my work bench and determined where the holes needed to be on the bracket. Marked and drilled them out. Then I transferred the pattern to the rails.
    I did not fasten the bracket with rivets!!! I used the rivets as holders so I could get the measurements to make the (2) backing plates for each side. The reason for (2) backing plates is that there is a plastic rib inside the rail that I did not want to remove as I can only assume this helps the rails retain their rigidity.
    Backing plates all cut out
    I used stainless steel allen button head bolts painted black to sandwich the factory rails with the brackets and the backing plates. If you have or have seen the factory roof rails you will understand that prior to doing this I had to make some complex bends in the brackets so that they conformed to the rails perfectly. Otherwise if I did not do this, when I tightened the bolts down I am pretty sure I would have cracked the factory rails.
    Now it is time to get the light bar up on the roof and tack the tubing in the brackets. After sliding the tubing into the holes I cut out of the brackets I obviously measured side to side to make sure the light was centered.
    Next was the wiring. Unfortunately I do not have a lot of pictures of this part. I cut a small slot at the base of the factory rails so I could slide the rigid harness up to a bigger hole I drilled on the side of the rail. The harness was held tightly in place with a grommet then everything was RTV'd. As for running the harness inside I drilled a hole in the roof and used a compression grommet along with RTVing it too. As of now 4 months later and through some massive rains in Florida I have no leaks at all.
    The I ran the wire down the pillar separating the front and back seat, along the floor and out through the firewall of the truck to my distribution panel.
    Here is a couple pictures of my distribution panel called The Source and is made by SPod. This system is awesome!!!!
    Location of where The Source is going to be installed
    The mounting bracket installed
    The Source fastened to the mounting bracket.
    --The wires at the bottom of the pic are the wires from the switches
    --Next up are the fuses for each circuit
    --Then you have the relays for each circuit
    --Then you have the output terminals (+ & -) for each circuit.
    The Source comes with a push button reset circuit breaker
    And The Source even comes with a nice lid to keep crap from getting to all the electrical components.
    A later picture of the finished 40" light bar project
    Unfortunately I seem to have lost the pictures of how I built the brackets for the 30" light bar in the bumper, but here is a picture that Tim from BDF posted about how he was planning on mounting a light in the bumper. I took his idea and modified it a little bit. This will at least give you an idea anyhow
  2. Nov 25, 2012 at 6:30 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Uhhhhhh. Pics of that all lit up?
  3. Nov 25, 2012 at 6:37 PM
    masterwacker
    Paul
    Orlando
    Good point. Pictures added.
  4. Nov 25, 2012 at 6:58 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    wow! awesome. that looks like day time
  5. Nov 25, 2012 at 7:02 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Thanks for showing us how you got it done!!
    +1!
  6. Nov 25, 2012 at 9:42 PM
    benbacher
    Anchorage, AK
    Definitely cool. Hahahaha not a cheap project to be sure, but install looks clean. Hope nobody jacks those.
  7. Nov 26, 2012 at 1:15 PM
    60driver
    60driver Well-Known Member
    Sean
    CT
    10 DC TRD Sport 4x4 Tim Mica
    Illum 4x4 switch, 20" LED bar in lower grill, LED in scoop, aux fuse box, avid light bar and 'sliders'
    Awesome, thanks for the write up. I was wondering how you wired all that stuff.
  8. Nov 26, 2012 at 1:19 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    do you have anymore close up pics of the final product?
  9. Nov 26, 2012 at 1:43 PM
    60driver
    Sean
    CT
    Did you use the included switches? How did you set up that many?
  10. Nov 26, 2012 at 1:43 PM
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    I love it!!!
  11. Nov 26, 2012 at 4:48 PM
    Maynard
    Maynard New Member
    Phx
    07 Tacoma 4X
    Suspension, tires, wheels, lights, stereo
    Great write up on your install..That is a clean install- I think it looks great.
    Would you happen to have any close up photos or details of your hood-scoop setup? Did you have to fabricate something for the scoop light, or did you use a Rigid cradle, or what for mounting it? Thanks.
  12. Nov 26, 2012 at 7:13 PM
    jmast
    jmast Is it June yet
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    fuuuuuuuuck:drool::drool::drool::drool::drool::drool::drool:
  13. Nov 26, 2012 at 7:53 PM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    do a build thread of that, i'd like to see another angle of how its done.
    OP, thanks for posting, this is exactly what i've been waiting for since you first posted pictures of your truck
  14. Nov 26, 2012 at 8:45 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    So nice....
  15. Dec 10, 2012 at 5:42 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    hood scoop & grill are overkill....but nonetheless nice. roof & bumper installs are clean as hell.
    outxider likes this.
  16. Jan 31, 2013 at 10:13 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
  17. Feb 1, 2013 at 8:32 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
  18. Feb 3, 2013 at 4:00 PM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    What size tires are you running? Looks super good man you have the cleanest set up on here.
  19. Feb 3, 2013 at 4:10 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wholly hell that's a lot of (expensive) lighting :drool:
  20. Feb 3, 2013 at 4:30 PM
    masterwacker
    Paul
    Orlando
    Thanks. I am currently running 285/70R17 BFG AT/KO
