Rim Bolt Pattern
Discussion in '1st Gen. Tacomas (1995-2004)' started by Woodcutter, Nov 10, 2020.
  1. Nov 10, 2020 at 1:50 PM
    Woodcutter
    Woodcutter [OP] Well-Known Member
    Missouri
    3.4L V6 96 Taco 4 x 4 SR5
    Hey all, now looking for OEM rims for my '96TACO. Just a plain, steel rims wanted. The door tag indicates a rim of 15 x 7JJ, this is a 6 lug rim. Found Blackburns on RockAuto but sizing is confusing with several sizes based on the bolt pattern. So how do you figure the bolt pattern? Any advice appreciated.
  2. Nov 10, 2020 at 1:51 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Assuming your profile is correct and you have a 4x4 6 lug the wheel pattern is 6x5.5" AKA (6x139.7mm)
  3. Nov 10, 2020 at 1:54 PM
    Wulf
    rock raisin
    This is a great point. There are a lot of GM wheels that have the same pattern but the hub bore is too small to fit these trucks. Likewise, aftermarket steel wheels are likely to have caliper interference issues.
    OP, your best bet is to keep an eye out for used OEM Yota wheels.
    whatstcp[QUOTED] likes this.
  4. Nov 10, 2020 at 7:14 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    I think this part was overlooked. The are no 4x4 5 lug Tacomas. So if you have a 5 lug wheel the truck is not a 4x4.
    5 lug = 5x114.3
    6 lug = 6x139.7
    whatstcp likes this.
  5. Nov 14, 2020 at 8:19 AM
    Woodcutter
    Missouri
    My error my truck is a 4x4 and does have 6 lugs. Thanks, khail19
