Rim Compatibility (97 4x4)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mikeyjd, May 24, 2014.
  1. May 24, 2014 at 7:41 AM
    Mikeyjd
    Mikeyjd [OP] MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    I am wondering if there is a complied list of compatible rims. If not, does anyone know which rims are common swaps?
  2. May 24, 2014 at 11:49 AM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
  3. May 24, 2014 at 9:11 PM
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
  4. May 24, 2014 at 10:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    All Toyota 6 lug wheels will fit your truck. This includes pre-tacomas, 1st and 2nd gen Tacomas, T4Rs (all gens), T100s and early 1st gen Tundras.
  5. May 25, 2014 at 9:24 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    The bolt pattern might be the same but watch out for backspacing.
  6. May 25, 2014 at 2:48 PM
    Mikeyjd
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    I picked up these 2010 Pre-runner rims with 60% dunlop grandtrek at20 tires on them today for $100!! They fit nice and ride so much better than my cooper discoverer a/t's.
