RIM FITMENT QUESTION
Discussion in 'Wheels & Tires' started by spdracer71, Sep 23, 2010.
  1. Sep 23, 2010 at 4:21 AM
    spdracer71
    spdracer71 [OP] Member
    Donny
    Raleigh, NC
    Tacoma 2.4L
    I have a 1st Gen Tacoma 2wd 2.4L (Little truck) that has offset 15 inch steel wheels that came with the truck when I bought it.
    I wanted go to a stock non offset wheel cause I am tired of them spraying water/mud up the side of my truck. Do the Mazda and Nissian truck wheels fit my bolt patterns. I am thinkin on trying to locate a stock set of wheels via Craigslist OR the junkyard.
    Thanks
  2. Sep 23, 2010 at 4:51 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    ok may need more info like yr of your truck yr of truck your going to get the wheels from
    But the bolt on your truck 1st gen with 15inch 2wd is 5-114.3
    the nissan frontier king cab also 15inch wheels 2wd is 6-139.7
    the mazda wheels are also in a 15inch 2wd 5-114.3
    now you said it was a 1st so all this info i used was from yr 2002 trucks
    hope this helps
  3. Sep 24, 2010 at 3:07 AM
    spdracer71
    Donny
    Raleigh, NC
    Tacoma 2.4L
    Its a 96 yr model with 5 lug bolt pattern. I think that the original wheel size was 14 in. THanks for you info.
  4. Sep 24, 2010 at 3:23 AM
    David Tarantino
    N.J.
    08 tacoma
    I show all 1996 tacomas with 14 inch wheels have a bolt pattern
    of 4-114.3 all with 15 inch wheels at 6-139.7
    all nissans p/u had a bolt pattern on 6-139.7 with 14 or 15 inch wheels
    mazda b2300 p/u had a bolt pattern of 5-114.3 14/or 15 inch wheels
