Rim Noob
Discussion in 'Wheels & Tires' started by 06TacomaTRD, Jul 21, 2011.
  1. Jul 21, 2011 at 6:47 PM
    06TacomaTRD
    06TacomaTRD [OP] Well-Known Member
    Brett
    South Carolina
    2011 MGM TRD OR PreRunner
    See Link --->
    First of all, I am an idiot when it comes to understanding the specs of a rim so bear with me as I ask a few questions. :cool:
    The Background:
    I am looking into getting a Pro Comp 8179 in 16x8 as shown here:
    http://4wheelonline.com/Pro_Comp_Wheels_8179_Gloss_Black_w_Machining.142087.0
    I currently have 265/70/16, but plan to get 265/75/16 once these tires wear out.
    Based on what I see on the webstite, the offset for this rim is 0mm with 4.5" bs. From what I have seen and understand, a 4.5" will fit either 265/65/16 or 265/75/16. Am I correct?
    I don't know if this information is necessary, but I am running my truck stock as of right now, but may be adding Bilstein 5100 all around in the next month or so.
    Appreciate it!
  2. Jul 21, 2011 at 7:21 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Edit: fit either 265/70/16 or 265/75/16.
  3. Jul 21, 2011 at 8:40 PM
    ssmskot
    ssmskot Well-Known Member
    Maine
    '07 Base 4x4
    Soft Tonneau. Tint. Toyota bed mat. K&N Air Intake. 265/75/16 BFG AT's. Sport grille. Weathertechs.
    you are correct sir. only thing i would try to research is whether or not that particular 16" wheel will clear the brake calipers on your 2nd gen.
  4. Jul 22, 2011 at 3:53 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    How do I figure that out? By measuring 4.5 inches from the inside of the rim? If it does not, would spacers be something that may solve this issue?
  5. Jul 22, 2011 at 4:26 AM
    EndlessSummer
    EndlessSummer Well-Known Member
    Sonora, CA
  6. Jul 22, 2011 at 7:26 AM
    Mescalero
    Mescalero Beretta Taco
    Clemson, SC
    '10 PreRunner DCLB BSP
    5100's x 4, radar detector, dual usb plug, mag-light, satellite radio hard wire
    do they have any in 6x197 bolt pattern? or do you have an older model?
  7. Jul 22, 2011 at 7:59 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    6x139.7
  8. Jul 22, 2011 at 3:21 PM
    ssmskot
    Maine
    '07 Base 4x4
    Yeah spacers would solve the issue.
    You may be all set though. 4.5" backspacing is what you want. Its just some wheels, because of the spoke design, still hit the calipers.
    If you don't mind running spacers then I would just order the wheels, and when they come in do a test fit, if they rub, order your spacers.
    Edit: OP I just looked at that site you linked again, don't even see the correct bolt pattern listed for the 16s.
  9. Jul 22, 2011 at 5:07 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Thanks for the input so far. I will look into the spacers as well, just in case.
    That website does not show the bolt pattern, but I did some searching and found a website that showed two types: 8 on 170 and 8 on 6.5 whatever that means :confused:
    Website: http://www.4wheelparts.com/Wheels/P...kspace_PQ=4.5&Diameter_PQ=16.00&Width_PQ=8.00
  10. Jul 22, 2011 at 5:25 PM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    Just a heads up, check with procomp before you order. The majority of there wheels are on back order. The lost there previous manufacture and are in the process of getting a new one. I had an order placed for some 7089 but cancelled when I was told the earliest would be September but not even 100% sure about that because none are currently being produced.
  11. Jul 22, 2011 at 7:35 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Thanks for the heads up!
