rim offset for 285s? need links can't figure out rims. black
Discussion in 'Wheels & Tires' started by rruhl48, Jan 27, 2014.
  1. Jan 27, 2014 at 8:15 PM
    rruhl48
    rruhl48 [OP] Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    Trying to decide between 265 75 16s or 285 75 16. Possibly 275 70 16. Looking at cooper discoverer or In the 265 75 16...installing bilstien5100 setting at 1.75. For down travel... sway bar bracket diff and skid plate 1inch spacer then aal in back full length not shorts. Thinking Fox 3 inch lift shocks Rio account leaf and help the bounce trying to tow my 24 foot angler and a ton of pellets at a time.. truck doesn't see much of road but I deff play when it snows and dts wondering what offset id need to run and rim with looking for black rims for the 285s but hesitant to have to chop cab mounts and lose front mud flaps. Any info or links I'd really appreciate thanks guys
  2. Jan 28, 2014 at 10:33 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    You'll need a negative offset wheel for the fatty tires to keep them off your uca's.
  3. Jan 28, 2014 at 10:35 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    4.5'' BS works for me.
  4. Jan 29, 2014 at 5:38 AM
    rruhl48
    Rick
    union county NJ
    I'm assuming that's a 16 x 10 or 8? Any offset or just 4.5 backspace. Thanks I think I'm ganna stick to 265 75 16s and rock the stocks
  5. Jan 29, 2014 at 5:46 AM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    with only 1.75" of lift in the front, your most likely going to have to do major trimming, lose mud flaps, and possibly CMC. From what ive read, it seems an 8" wide rim with 4.5" of backspacing will give you the most clearance you need to run 285's. Im running a 16x8 procomp 7089 with 4.5" of backspacing and 265/75/16 Duratracs. I plan on moving up to 285's in the near future and will probably still have quite a bit of trimming with OME 885x coils and 5100's at 0" in the front and wheelers 1.5" progressive AAL in the rear. Check my build for pics, hope this helps
  6. Jan 30, 2014 at 3:25 AM
    rruhl48
    Rick
    union county NJ
    Yea thanks. Deff v arriving with ,265 75 16 cooper atp lr e. Thanks. Stock rims on sr5 should do it for now
