Rim Size
Discussion in 'New Members' started by NH03TacomaTRD4x4, Oct 7, 2009.
  1. Oct 7, 2009 at 4:10 PM
    NH03TacomaTRD4x4
    NH03TacomaTRD4x4 [OP] Well-Known Member
    Doug
    New Hampshire
    03 TRD Double Cab 4x4 Tacoma
    Hi Guys I just joined this forum after searching the web to find my rim size on my yota.
    I have an 03 Tacoma double cab 4x4 TRD Off Road pkg with 16" rims that take the 265/70R16 Tires........
    My question is 16"x ? Rims I know the following specs
    Toyota Tacoma (4WD)
    Bolt Pattern (in): 6x5.50
    Bolt Pattern (mm): 6x139.7
    Offset Range (mm): -4 to 20
    Wheel Size Range (in): 16x7.0 to 22x9.5
    Front Center Bore (mm): 106.1
    Rear Center Bore (mm): 106.1
    Stud_Size: 12x1.5
    Thx for any help!
  2. Oct 7, 2009 at 4:12 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    you mean the stock wheel width?
  3. Oct 7, 2009 at 4:24 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    Yes Stock wheel width!
    I guess i should have posted this in the Rims and tires thread...can a mod move it there pls.
  4. Oct 7, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Oct 7, 2009 at 4:36 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 Then the widest tire you may be able to fit is a 285 ;)
  6. Oct 7, 2009 at 4:42 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    What about running 265/75R16s instead of 265/70R16s any issue with that?
    Thx
  7. Oct 7, 2009 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those will work just fine.
  8. Oct 7, 2009 at 4:44 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    x2^^^
  9. Oct 7, 2009 at 4:57 PM
    NH03TacomaTRD4x4
    Doug
    New Hampshire
    I guess I should add that my truck is completely stock!
  10. Oct 7, 2009 at 5:19 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    welcome to the forum!
  11. Oct 7, 2009 at 7:48 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    hello & welcome to TW.
