Rim sizing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaGirl83, Feb 5, 2023.
  1. Feb 5, 2023 at 5:32 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A 20” rim with a 33” tire will ride nearly identical to a stock Tacoma since it has the same contact patch and sidewalk height. You can even air it down exactly the same as a stock Tacoma. You obviously give up a lot of advantages compared to the same 33” tire on a 16” rim but when compared to stock it’s near identical.
    I wouldn’t do it on a Tacoma but it’s not a performance killer for a normal daily driver.
  2. Feb 5, 2023 at 9:07 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    Yotalicious, blu92in99 and Squirt like this.
  3. Feb 5, 2023 at 10:02 PM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I'm not entirely sure how you figure that you would have almost double the sidewall to an average car or crossover especially if we're considering "stock equivalent" sizing. A Corolla L has 195/65R15 wheels which have 5" of sidewall, similarly a 265/50R20 wheel would have a hair over at 5.25" of sidewall. :confused: From my own experience I never go for high trim packages on vehicles I buy.
    If a stock tire is 265/70R16 on a TRD OR or 265/65R17 on a TRD Sport and you're going up to a 20" wheel with 33" tires on you may not get the same sidewall height, you may be getting less sidewall really. Depends entirely on actual tire sizing I guess, my 255/85R16 Coopers are "33s" but only 32.64" or something like that lol.
    I would think even if you kept it "stock equivalent" you'd gain a form of performance, though a lack of comfort. "Better" handling depending on your perception. Read: the ability to feel the road.
    Braking should be within the same length/time, weight might even be fairly similar depending on wheel and tire choice. Stock Tacoma TRD OR wheel and tire was about 65-70lb total I believe, find a nice light 20" wheel and you should weigh in to about the same.
    @YotaGirl83 if you're having issues finding 20" wheels that fit Tacomas, Fuel Offroad carries a HEAP of styles in 20" with correct fitment for Tacomas; bore size n all. Some are pretty weighty, over 40lbs but some I was checking into sat around 30-35 for their 1pc wheel offerings so you've got some research to do. Find something that gives you a good weight balance, my unsprung weight is sitting around 90lbs and it's brutal!
    Enjoy your search and enjoy your ride! :thumbsup:
    BC Hunter likes this.
  4. Feb 5, 2023 at 11:46 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The OP didn’t mention a lift , so a 33” tire is unlikely to fit. A 265/50 on a 20 inch rim is very close to stock diameter .
    Something like a Nitto Ridge Grappler might be an option. Premium tire, but any 20 inch option is going to be spendy.
  5. Feb 6, 2023 at 12:35 AM
    PoolFixer
    PoolFixer Well-Known Member
    22 MGM AC SR5 V6 2WD
    OEM TRD headlights, bed lights
    How much extra for a lift and proper suspension and other upgrades that aren’t going to wear out drivetrain parts prematurely?
  6. Feb 6, 2023 at 12:40 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Squirt likes this.
  7. Feb 6, 2023 at 6:12 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    $0. You don’t need a lift to fit larger diameter tires. You could run 265/65/20 on stock suspension and be fine.
    photogr4x4 likes this.
  8. Feb 6, 2023 at 6:39 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    Nothing wrong with 20's on a truck. I have a friend with the Limited 20's on his new 4Runner which look great. Another friend has factory 20's on his Canyon; looks good and on decent roads it still rides better than my Tacoma on 17's. They're not doing any "real" off-roading, just some dirt/gravel trails and beaches.
    BUT... my friend with the Canyon recently had a sidewall blowout from an especially nasty pothole, so that might be a consideration depending on where you live.
  9. Feb 6, 2023 at 6:48 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Nice to see this thread go full Tacomaworld in less than 24 hours.
  10. Feb 6, 2023 at 7:02 AM
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    I think the people that worry about airing down their tires to do serious off-roading should probably get a vehicle that is actually made for off-roading and not made and marketed to middle class office people that hit a trail every other weekend lmfao. "Look guys I spent $10k+ doing a front SAS to be barely as capable as a jeep wrangler!"
    “Look guys i butchered my cab mounts just to fit 35’s”
  11. Feb 6, 2023 at 10:17 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    No where in the O.P.'s post do i see anything about offroading. She just asked about fitting
    20" wheels.O.p, if you go to the custom offset website I believe there is a fitment guide, and I think there are some on the bigger tire and wheel websites as well.
    photogr4x4 and BC Hunter like this.
  12. Feb 12, 2023 at 10:58 AM
    PoolFixer
    Good to know thanks. How’s the ride with such a skinny sidewall?
  13. Feb 12, 2023 at 10:59 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    It’s the same sidewall height as a stock Tacoma so it should be about the same ride quality.
    PoolFixer[QUOTED] likes this.
  14. Feb 12, 2023 at 11:19 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Ya, that’s not even a little true. Not. Even. A little.
    Good luck running 33+” tires on stock suspension.
  15. Feb 12, 2023 at 11:21 AM
    #35
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Done it already, on more than one Tacoma.
    Blacktacoma23 likes this.
  16. Feb 12, 2023 at 11:26 AM
    #36
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    You don’t know what you’re saying. 265/65/20 is at minimum 33.5” tall.
    You’d be rubbing on any amount of turn if not just sitting in the wheel well straight on.
  17. Feb 12, 2023 at 11:27 AM
    #37
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Yep, absolutely clueless, never put a different tire on the Tacoma in my life. It’s ok though, you can go on thinking that a lift will make a bigger tire fit in the same size hole.
  18. Feb 12, 2023 at 11:30 AM
    #38
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    ok
  19. Feb 12, 2023 at 11:33 AM
    #39
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    What you need there is a baseball bat to roll the fenders out with. Do it on a hot sunny day to help keep the paint from cracking.
    AmateurTaco1313 likes this.
  20. Feb 12, 2023 at 3:51 PM
    #40
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Welcome to the club Nikki
