Rim,Tire, and drop question
Discussion in 'Street Trucks' started by mauiracer, May 8, 2011.
  1. May 8, 2011 at 3:04 PM
    mauiracer
    mauiracer [OP] Member
    05 tacoma
    hi i have a 05 taco its all stock except for the sounds and im looking at lowering it. whats a good kit to use that will give it a good look but wont be too low to scrape on anything, and also im looking at going with a mickey thompson rim about a 16 and a low pro street tire, i need the dimensions for the rim i was looking at going pretty wide. any suggestions would help im not very knowlegable so anything helps thanks
  2. May 8, 2011 at 5:04 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    For the lowering kit hit up brian at streetacos http://www.streetacos.com/
    best tacoma specialized stuff on the market.
    As for the wheels, you can run larger than 16s, and if your going with a lo pro tire you will probably want to to fill in that wheel well. You can get a wide tire, just make sure your off set it right so you have enough room to get the fender around it, and you wont be hitting your fender. Off set is a very important number to make sure you have proper clearence, so i would test fit the wheels and see what fits.
  3. May 8, 2011 at 8:14 PM
    mauiracer
    05 tacoma
    so the so the silver tacoma on the home page of that site what size are those and what drop kit thats exactly what i want
  4. May 8, 2011 at 11:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  5. May 9, 2011 at 10:41 AM
    mauiracer
    05 tacoma
    thanks man i appreciate it
  6. May 10, 2011 at 7:13 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    wow duh, my bad. I saw the rear drop for 2nd gens and assumed he had front stuff. Sorry about that.
