Rim width
Discussion in 'Wheels & Tires' started by gex2113, Mar 31, 2010.
  1. Mar 31, 2010 at 11:54 AM
    gex2113
    gex2113 [OP] Member
    I was looking to get new tires and wheels for my 2010 trd tacoma and I thought I would settle on the 16x8 steelies from wheelers offroad and BFG AT 235/85/16 tires. However looking up the specs on BFG's website it states Rim Width Range min max 6" to 7" in. Since the rims are 8 inches I am assuming these wont fit? Can anyone recommend a tire that is of similar proportion if that wont fit? Thanks
    ~Carl
  2. Apr 1, 2010 at 3:39 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I had this issue when I decided to go with a 9" wide rim and I wanted to stay with 265's...
    I was told that they will fit at 1" wider, but the issue is some/most tire shops won't install them so they can't be held liable is something happens. You could call a local tire shop and ask them if you really want that set-up. I like to be on the safe side and stick with what the manufacturer suggests.
    Why are you going with a 235?
  3. Apr 1, 2010 at 7:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The concern is probably that they're too skinny for that rim size. Try to find a tire with more width......
    I had to convert to inches -
    235/85/16 = 31.7 x 9.3 / 16
    I've run 33 x 12.50" and 35 x 12.50" wide tires on 8" wide rims on my jeep. In offroad terminology, too skinny a tire on a wheel can cause you to break the bead easier.
