Rimfire Pistol Recommendations.
Discussion in 'Guns & Hunting' started by bodean, Feb 9, 2021.
  1. Feb 13, 2021 at 10:10 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I have the Buckmark. It’s ridiculous accurate.
    I bought it because the latest Ruger is not CA compliant. Boo. The buckmark is so easy to clean because you basically can’t. I spray it down occasionally with gun spray and run a barrel snake down the tube. Easy! Goes against my OCD to make things spotless, but honestly the gun has never failed. I hunt bunnies with it and I’m surprised I’m so successful. It is easy to aim and shoot.
  2. Feb 13, 2021 at 10:26 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Us the slide polymer too? Looks like there's a mold or division line in it?
    tacotoe and bluewave like this.
  3. Feb 14, 2021 at 6:50 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Partially
    tacotoe likes this.
  4. Feb 14, 2021 at 6:58 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    The slide is hybrid (metal reinforced polymer). They had to keep the slide weight down because of the blowback design. I'm at about 3k rounds through the barrel, and I have had no failures. I have shot a lot of subsonic suppressed as well as Eley target and Aguila Interceptors. It eats everything. This has become my standard training pistol for day to day drills, as 9mm is scarce. As I said previously, it is exactly the same size as a G19. My only bitch is that mags are limited to 10 rounds, where the 19 standard mags are 15. If they just came out with a 15 round mag, this would be the perfect training tool.
    tacotoe likes this.
  5. Feb 14, 2021 at 7:12 AM
    JimBeam
    JB
    2015 Tundra
    Promag has a higher capacity mag for it
  6. Feb 14, 2021 at 7:15 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    I've enjoyed my Smith&Wesson M&P 22. Aside from that, the two best suggestions I can give are: first, 22s tend to be picky on the ammo they like. Before buying a bunch of one type make sure it's something that whatever gun you've chosen cycles it reliably. I've got a stack of winchester super x 100pks that are useless to me, constant malfunctions. Second, 22 ammo tends to be dirty. Keep whatever you buy clean and lubed. Bring your cleaning kit with you to the range so you can clean if you need to. Good luck.
  7. Feb 14, 2021 at 7:17 AM
    svermilyea
    Scott
    East Tennessee
    Thank you .... 3x on order :spending:
  8. Feb 15, 2021 at 3:27 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Ruger or Buckmark it really is a toss up, I have been shooting a Buckmark for a few years now, very accurate, I have used a verity of different sights/scopes and generally enjoy the pistol (although it doesn't get much use anymore
    tacotoe, Sig45, wrightme43 and 2 others like this.
  9. Feb 15, 2021 at 3:47 PM
    aficianado
    back to bone stock.
    My buckmark is the Contour model. Added complications of having to get a holster made for it. Nobody sells one.
  10. Feb 15, 2021 at 3:55 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    love my 22/45 lite! The aluminum receiver and polymer frame make it a much more manageable weight for a 22 pistol.
    I compared it to a stainless target model when I was shopping and the all steel model felt comically heavy for a 22
    tacotoe likes this.
  11. Feb 15, 2021 at 5:29 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I have this as well. Tack driver.
    That one old guy and tacotoe like this.
  12. Feb 15, 2021 at 6:06 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Another vote for the S&W Victory .22! The one I have shoots everything I load in the magazines and is very accurate. Easy to clean as well. The aftermarket parts are pretty extensive too.
    tacotoe and Brownie_Man like this.
  13. Feb 16, 2021 at 12:22 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    ive shot both the buckmark and ruger, ended up with the ruger because it was threaded and readily available at the time of purchase
    you cant go wrong with either
    tacotoe likes this.
  14. Feb 25, 2021 at 7:23 PM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    I have been looking for a Ruger Mk 4 22/45 tactical for months.....
    still looking.
    tacotoe likes this.
  15. Feb 25, 2021 at 8:38 PM
    #35
    bodean
    bodean [OP] Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Apparently the application process is so backlogged that we are looking at about another 4 months before we can actually purchase anything.
  16. Feb 25, 2021 at 8:53 PM
    #36
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    That sucks. Gives you more time to make a decision. :D
    I have a Buckmark, but would buy a Ruger.
  17. Feb 26, 2021 at 2:25 PM
    #37
    plurpimpin
    PDX
    I love my Ruger MK IV Lite. I went in the store knowing I wanted a MK IV but was on the fence between the Lite, Tactical, and a Stainless target models.
    After handling all 3 the Lite was the obvious choice, it was comfortable and well balanced. The Steel receiver Tactical and especially the all stainless target models just felt comically heavy for a .22 pistol. They were heavier than my full sized HK45 Tactical which just seemed overkill for a 22 plinker.
    tacotoe likes this.
  18. Feb 26, 2021 at 6:02 PM
    #38
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    S&W Model 41
    tacotoe and Dave3359 like this.
  19. Feb 26, 2021 at 6:55 PM
    #39
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I've had the Ruger 22/45 for maybe close to ten/fifteen years and have shot numerous rounds of standard 22lr various brands no issues. It is rather heavy but also accurate. My only complaint on this model I have the grips aren't easily changed out likes other Ruger 22's the newer model 22/45's might be different. I also much more recently purchased TX22 it's nice, works fine, accuracy meh, ok. Wife likes it as it is lighter and better feel to her.
    Some of those Buckmarks are cool looking, futuristic lol, I've never tried one though.
    Price point on that Taurus TX 22 was very cheap with rebate.
    That one old guy likes this.
  20. Feb 26, 2021 at 7:06 PM
    #40
    PLYDRTY
    PLYDRTY Well-Known Member
    Jeff
    Haymarket, VA
    17 MGM TRD OR DCSB
    Love my used $175 Taurus TX-22. Great ergonomics, sweet trigger.
