Rims for extended taco 2001
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joni, May 24, 2015.
  1. May 24, 2015 at 6:56 PM
    Joni
    Joni [OP] New Member
    JB
    2001 tacoma
    Does anyone know if I can put highlander rims on a 01 taco. 5 lug?
  2. May 25, 2015 at 5:21 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I think the only issue with using any Toyota rims (other then lug count) is the back spacing (where the bolt on flat part of the rim is located) so test fitting might be your best bet since its hard to know if other things like brake calipers clear. sometimes everything looks ok but when mounted it may have tire rub in full turns or sit just outside the fender too much causing you to need fender flares.
    there is a thread here with info on rims: https://www.tacomaworld.com/threads/wheel-backspacing-and-offset-info.102992/
    and put in your truck here then compare to whatever wheel you want to use and see if they are the same http://www.myboltpattern.com/
    Joni[OP] likes this.
  3. Dec 19, 2016 at 12:06 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    The list stops at 2011.
