Rims: Positive Offset v. Neg. Offset
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLOH, Sep 3, 2009.
  1. Sep 3, 2009 at 1:53 PM
    SLOH
    SLOH [OP] Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    Looking to get 17X9 4.5 in. backspacing XD Series Addict with 285/70/R17 BFG KM2's.
    Imsikotic is running these and said his offset is a -12 and some trimming, got off the phone with a guy at a store and he said he thought i should be running a positive offset with my 3" lift, that the neg. offset would induce rubbing. Purchasing soon and looking for an answer.
    Also i have a long bed DC, imsikotic has DC shortbed, i HIGHLY doubt any dimensions regarding the wheel wells would be any different.
  2. Sep 3, 2009 at 1:54 PM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    He's not considering the UCA
  3. Sep 3, 2009 at 2:06 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    I would say your good Scott, since you're getting the same setup as Randy and he doesn't have issues. I have 16x8's with a 0 offset and i rubbed. With most (i say most because there are some out there who have actually fit 285's without a lift and no rub) 285/33' tire trimming will be involved.
  4. Sep 3, 2009 at 2:09 PM
    Padilla1880
    Daniel
    Temecula, CA
    Oh yea make sure you get a hub centric wheel instead of a lug centric wheel.
  5. Sep 3, 2009 at 6:05 PM
    SLOH
    Scott
    Los Angeles
    are you talking about a spacer? i'm not gonna run a spacer and just have a little trimming done, hopefully my truck will be fixed and and i'll have the new tires on by ocotillo, i'm trying to figure out how to get pictures in a thread without doing the attachments...shoot me in the head
  6. Sep 3, 2009 at 6:10 PM
    Padilla1880
    Daniel
    Temecula, CA
    No. There are two different wheel types hub and lug. Our trucks are hub centric. So make sure you get wheels that are hub centric.
  7. Sep 3, 2009 at 6:15 PM
    SLOH
    Scott
    Los Angeles
    alright well Randy is already running them and i talked to him about them so i'm assuming they are a safe purchase cause honestly i don't know if they are hub or lug centric, do you have any idea how to post pictures from your computer into a thread
  8. Sep 3, 2009 at 6:20 PM
    SLOH
    Scott
    Los Angeles
    nvm i got it
  9. Sep 3, 2009 at 6:58 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    I'm running the same size wheels/tire size and I went with a -6mm offset. Some trimming had to be done to end the rubbing issue but other than that it should be fine. look in my pictures to see some of the clearances
  10. Sep 3, 2009 at 7:09 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm running 18x9's with a -12 offset. Tires are 285/65-18"s with some minor trimming involved.
  11. Sep 3, 2009 at 7:50 PM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    i'm running 17x9 4.5" BS -12mm offset and I rub on the cab mount when i'm backing up and turning pretty much to full lock. I either have to lift it more or trim the cab mount
  12. Sep 3, 2009 at 9:00 PM
    SLOH
    Scott
    Los Angeles
    so everyone is pretty much running negative offset, so why the fuck did the guy tell me to run positive? i have stock UCA btw
  13. Sep 4, 2009 at 10:21 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I have lug-centric on mine with no problems. The hub on the Tacoma is bigger than most hub-centric wheels so many won't fit. The hub-centric version of my wheels won't fit.
  14. Sep 4, 2009 at 11:02 AM
    Padilla1880
    Daniel
    Temecula, CA
    Mine are lug centric also. When i first had them installed, no probs. After my first rotation steering wheel shudders at 45-65. Took it back twice for rebalance. After the second re-balance and more weights, shudders weren't as noticeable so i let it be.
    I was due for a major 136k+ so i took my truck into the stealership. Rotating the tires was included in the service. Noticed crazy shudders at freeway speed as well as city driving. Took it to Discount where i got my tires and had my wheels Road Force Balanced. Shudders gone!
    I guess it would all depend on the wheel. You have lug centric wheels and no issues i have lug centric wheels and had issues. My next rotation is coming up and if after the rotation i find shudders, then im ditching these wheels for a hub centric wheel. But like you said, "The hub on the Tacoma is bigger than most hub-centric wheels so many won't fit. The hub-centric version of my wheels won't fit," so again it would depend on the wheel you get.
  15. Sep 4, 2009 at 11:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    I don't think the guy knows what he is talking about. Positive offset moves the wheel closer to the truck (suspension components). The backspacing number is more relevant than the offset any way. The offset is a result of the basckspacing.
    https://www.rsracing.com/tech-wheel.html
  16. Sep 4, 2009 at 3:42 PM
    SLOH
    Scott
    Los Angeles
    yeah thats what i thought so thats why it just threw me off when the guy said that over the phone so i started the thread, and just a reminder, i'm not running any spacers, looks like from some of the pictures that some people that have responded have spacers
  17. Sep 4, 2009 at 3:44 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    no spacers
  18. Sep 4, 2009 at 4:01 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I have the -12mm offset, the 17x9 with 4.5" BS and had major rubbing with another brand of wheels. I HAD to run a small spacer which caused really bad rubbing but it was nothing that a little persistence and some ingenuity wouldn't solve.
    The argument about lug centric wheels vs. hub centric is not really all that important. If you run lug centric wheels (which is what almost ALL aftermarket wheels are) you just need to use a lug nut that is the acorn style that centers the wheel up on the lugs. That and a road force balance and you'll be set. There are even extended thread lug nuts made by Gorilla which I'm running that are the nuts! Check this link (bottom right corner) http://www.gorilla-auto.com/lug.nuts.page_08
