Rims/Tires and 3" lifts
Discussion in 'Wheels & Tires' started by Viper714, Jun 25, 2013.
  1. Jun 25, 2013 at 7:13 AM
    Viper714
    Viper714 [OP] New Member
    Charlotte NC
    Tacoma TRD
    Guys, I have searched the forums here for over a month for an answer to what appears one of the most commonly asked questions, Each time I think I know the answer I stumble across another post that contradicts the last so I apologize I have to ask for clarification. I am planning to do a 3'' suspension lift on my 2009 Taco and put on 285/70/17 tires on KMC XD SPYs. The rims are 17x9 with -12 offset and 4.53 backspacing so from everything I have read so far I think they should work fine with the lift. What I dont understand is why some posts say you will need to trim or do something called a cab chop and why other say no rubbing issues at all even with 295s. How do you know beforehand if those tires/rims will work or rub? I dont do any off roading with the exception of gettting to my deer stand but i want to understand what kind of mod work i may have to do and why before I make these changes. Any insight would be appreciated. Thx
    2009 Tacoma Crew Cab
    TRD Off Road Package
  2. Jun 25, 2013 at 7:29 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    You usually just have to try and see. The trimming is the inside of you fender flares and ditching the mud flaps if you haven't already and the cab mount is usually only hit when flexed at full lock I believe. The rub/no rub thing is hit or miss. Some people run the same wheel and tire setups and one person rubs and the other dont. It's just try and see what happens and be prepared to do a little extra to make it work.
    And welcome to the forum.
  3. Jun 25, 2013 at 7:42 AM
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
    Welcome!!!
    My sons 2008 Tacoma Sport 4x4 DCLB has the 17x9 spys with287/70 duratracs with LR ucas and we had to definitely trim the inner fenderand do the CMC. It would rub just turning in reverse and forward. This was justmy experience and I didn’t want everyone turning around and looking my way tosee what that noise was.
  4. Jun 26, 2013 at 1:40 PM
    Viper714
    Charlotte NC
    Tacoma TRD
    Thanks for the info and quick response guys, I will just pull the trigger on the upgrades and hope I am one of the lucky ones with no issues!! Will post how bad r good it goes
  5. Jun 26, 2013 at 1:43 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    You will trim a lot.. trust me. I have the same spec wheels with gy duratracs and it rubs a ton
  6. Jun 26, 2013 at 1:53 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Dont buy 285s and hope to not trim, then be disappointed. Do buy 285s and plan to trim, and if you dont have to then you will be happy lol. There are more factors than just wheel offset/backspacing and amount of lift vs. tire size, those are the main factors though. Aftermarket UCAs can move the wheel back in the wheel well a little bit and increase the chance that the tire will rub the body mount. Alignment also can play a role in where or if you will rub. The tread pattern on the tires you buy can matter, how you drive the truck can matter also. The width of the wheel can actually affect the height and width of the tire (fractions of a inch) also which could possible change things. Basically what i am saying which i always try to tell people is there are to many factors to determine if you will or will not rub with 285/70/17, 285/75/16. I still find it hard to believe that some people claim to have NO rubbing or trimming with 285s after the amount that i had to trim and i still rub on occasion.
  7. Jun 26, 2013 at 2:02 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Don't want to cut? Go with 265s. Otherwise embrace it and grab some tools.
  8. Jun 26, 2013 at 4:12 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I run 295/70/17 on a 3" lift. Trimmed the fenders a fair bit. Minimal rub most of the time as is
  9. Jun 27, 2013 at 10:38 AM
    Viper714
    Charlotte NC
    Tacoma TRD
    When you guys say trim the fenders do you mean the interior of the wheel well or do you mean the actual fender itself? I think I agree with Evan and am going to plan on having to trim and if it doesnt have to happen then that will be a suprise.
  10. Jun 27, 2013 at 10:43 AM
    Monster Coma
    Corey
    No shouldnt have to trim the fender itself, maybe beat it with a BFH but no cutting. Atleast on mine I havent had to yet
  11. Jun 27, 2013 at 1:00 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    i had to trim my actual fender some. But I have 295s :rolleyes:
