Rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rdd, Nov 19, 2020.
  1. Nov 19, 2020 at 4:36 PM
    Rdd
    Rdd [OP] Member
    19 Tacoma 4cyl
    None
    If I were to replace my steel stock rims with new rims the same size would I be able to use the same tire ? Also could I use the same tire sensors ?
  2. Nov 19, 2020 at 4:45 PM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Tires yes, assuming the wheels are the same size 16,17 etc. Likely you can use the sensors as well. I've heard some aftermarket wheels have to have sensors with a certain angle or something along those lines.
  3. Nov 19, 2020 at 4:48 PM
    Rdd
    Rdd [OP] Member
    19 Tacoma 4cyl
    None
    Thanks
    I was thinking of getting some Used OEM rims . They seem to be cheaper and look pretty good , in my opinion
  4. Nov 19, 2020 at 4:49 PM
    NorNev
    Dave
    A Few
    A million and one options for wheels. Can't go wrong with oem wheels either
  5. Nov 19, 2020 at 4:56 PM
    UnconqueredNole25
    UnconqueredNole25 Well-Known Member
    2017 Tacoma SR5 double cab
    I just just installed some new aftermarket wheels and the shop didn’t have 4 new sensors so they used my old ones from my stock SR5 wheels. No issues so far.
  6. Nov 19, 2020 at 5:06 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Been through this. If your new rims are to be steel, then perhaps the old sensors will be compatible. If you are going to cast rims then new sensors will likely be required.
  7. Nov 19, 2020 at 5:08 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Most likely you will need new mag lugs
  8. Nov 19, 2020 at 5:12 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Different sensor on the steel VS aluminum is what i have found, also different lug nuts.
  9. Nov 19, 2020 at 5:39 PM
    Rdd
    Rdd [OP] Member
    19 Tacoma 4cyl
    None
    Might just save myself a lot of money and paint them
  10. Nov 19, 2020 at 6:27 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Steel rim tpms can be used in alloy rims but need to be turned around. There is another part for the tpms that fits the alloy rim. Also different lug kits too. Just make sure that the rim offset is the same so that no rubbing occurs.
