Rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by l_prettyman, Feb 13, 2010.
  1. Feb 13, 2010 at 1:20 PM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    ok can someone give me a lesson on rims? i have an 06 dbl cab taco, 6 lug. but i dont know what backspacing and the lug pattern and stuff means. please help
  2. Feb 13, 2010 at 1:23 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Its a 6 on 5.5 pattern.
  3. Feb 13, 2010 at 1:23 PM
    l_prettyman
    Logan
    06 4x4 SR5
    ah thanks so much. what offset looks good?
  4. Feb 13, 2010 at 1:29 PM
    krimson
    krimson Nothin
    TRD Off Road
    I think between a 4.5 and 5.5, im not sure 100%. I've never owned a set of aftermarket
    wheels, ive always been stock and upgraded the tires.
  5. Feb 13, 2010 at 3:51 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    6x137.9mm 0r 6x5.5, 4.5-5.5" backspacing. looks depends on what kinda tires your gonna get
  6. Feb 13, 2010 at 3:52 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    if you go with a wide tire you might want to look into 4.25" or even 4" backspacing
  7. Feb 13, 2010 at 4:16 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    back spacing is the distance from the backside of the wheel mounting pad to the outside of the rim flange.
    Lug pattern is determined by the number of bolt holes and the bolt circle diameter they form.
    Offset is the distance from the centerline (width divided by 2) of the wheel to the back of the wheels bolt pad or mounting surface. Offset can be a positive or negative number. Negative offset is when the back of the bolt pad is closer to the inside of the wheel; when the mounting surface is inboard of the rim centerline. Positive offset is when the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline.
    Hope this helps.
  8. Feb 13, 2010 at 7:59 PM
    l_prettyman
    Logan
    06 4x4 SR5
    helped quite a bit thanks
  9. Feb 13, 2010 at 8:03 PM
    wingshootin
    wingshootin Well-Known Member
    Jonathan
    Columbia, SC
    2006 Taco LB TRD Sport 4x4
    3" suspension lift Custom wheels Oversized M/T tires
    I just ordered some 17x8's with a 4 backspace and a 0 offset. I plan to run 295/70/17's with them hopefully. Some trimming will be involved.
  10. Feb 13, 2010 at 8:04 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    I have KMC Enduros at 0 Offset and a 4.5 Backspacing. It sticks out more than stock...and looks nice.
  11. Feb 13, 2010 at 8:08 PM
    l_prettyman
    Logan
    06 4x4 SR5
    picture?
  12. Feb 13, 2010 at 8:13 PM
    TRICOMA
    Tri
    Carlsbad, CA
    You can't really tell how far they stick out on these pictures but here you go anyways.
    Kings set at 2.5 in the front and TSB in the rear. Those are also the Stock Rugged Trails 265/70/16.
  13. Feb 13, 2010 at 8:34 PM
    l_prettyman
    Logan
    06 4x4 SR5
    • 18x9, 6 on135 And 6 on5.5 Bolt Pattern
    • Backspace 4.53 in.
    • Max Load = 2200lbs
    • Finish = Matte Black
    • Hubcentric = No
    • Offset = -12 mm
    how would that look on an 06 double cab? i want them to stick out but not out over 2 inches from the fender
  14. Feb 20, 2010 at 6:27 AM
    saf023
    East Coast
    If your numbers are correct and assuming you are starting with 17 X7.5 stock rims with a 30mm offset, you will lose no clearance on the inboard side and the outboard side will extend out an additional 1.5" farther than the stock wheels.
