Ring and Pinion 4.10 F/S
Discussion in '5 Lug' started by Rconectn, Nov 2, 2011.
  1. Nov 2, 2011 at 12:33 PM
    Rconectn
    Rconectn [OP] Well-Known Member
    Miami, FL
    '10 Regular Cab
    I'm posting this here because this is from a T100 that can also be used for our 5lug.
    I have this used set that a never got a chance to install when I was going for bigger tires at one point. I am selling this R&P for $165, which includes S&H.
  2. Nov 5, 2011 at 6:17 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    What size diff does a 5 lugged have?
  3. Nov 5, 2011 at 6:19 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    8.4 i think
  4. Nov 5, 2011 at 6:19 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Hmmm.
  5. Nov 5, 2011 at 7:01 PM
    bluetaco99
    bluetaco99 Well-Known Member
    michael
    chino ca
    06 5lugger
    im running 32" tires on my 5lugger now might have to take a look into this! =] do you know the stock gears on us 5luggers?
  6. Nov 5, 2011 at 7:02 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Think stock is 4:10
  7. Nov 5, 2011 at 7:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Previous info was incorrect and is now changed. Thank you afd23a!
    5 luggers come stock with 3.58 in Auto and 3.31 in manual.
    Also the gears from the 5 lugger will not fit in the 6 lug rear end. They are both 8.4 but something in the 3rds are different, I'm thinking it is the physical size of the gears based on statments in a different forums.
    My previous info was wrong I went to thinking 4 banger 4wd when I read 5 lugger. They come with 4.10 gears and are only enterchangable with the rear ends on the 6cyl non Elocked rears. The front ends don't swap directly either.
  8. Nov 5, 2011 at 8:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    5 luggers don't come with 4.10's, at least the 2nd gens don't. They come with 3.31 or 3.58 gears. The 4 banger 4wd and prerunners come with 4.10's.
  9. Nov 5, 2011 at 8:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ +1 for you, I have corrected my previous post.
  10. Nov 5, 2011 at 8:40 PM
    afd23a
    The Dynamo of Dixie
  11. Nov 10, 2011 at 5:15 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Ecgs sells a used t100 4.10 ring and pinion for 145 + shipping. Hook it up for your truck buddies :D
  12. Nov 10, 2011 at 5:22 PM
    saugus
    saugus Well-Known Member
    What's the OP r&p for? If I have a 5 lug manual, what tire size will work best with 4.10?
  13. Nov 10, 2011 at 8:02 PM
    afd23a
    The Dynamo of Dixie
    31" same as a 4cyl 6 lug
  14. Nov 11, 2011 at 6:33 AM
    saugus
    So if the stock tire is ~27", and I want ~29" and this r&p is for 31"...
    is there another r&p for me?
  15. Nov 11, 2011 at 6:57 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    You don't really need to regear for that
