Ring and Pinion change
Discussion in '4Runners' started by Ehutch708, Mar 20, 2022.
  1. Mar 20, 2022 at 3:37 PM
    Ehutch708
    Ehutch708 [OP] New Member
    2019 Toyota 4 Runner TRD 4x4
    As of now it is stock but am needing to change out the factory exhaust.
    I have a 2019 Toyota 4 Runner TRD 4x4. It has a 3 inch lift and 295 55 R20 wheels and tires on it. I want to change the front and rear end gaers to improve the torque and help with the bigger tires and wheels. Where is the best place to buy the parts for this job?
  2. Mar 20, 2022 at 3:41 PM
    TacoTuesday1
    FL
    I'd check out the popular ones, just search gear and see who pops up
    -Revolution
    -Yukon
    -ECGS
    etc.
    Probably gonna need at least, front and rear:
    -master install kits with bearings and shims
    -ring and pinion gears the size/ratio of your choice
    If you install it yourself would be awesome if you make a DIY
    Some people do it themselves, others pay a shop/or source pre-assembled third members to bolt in and return their original as core
