ring and pinion question i need help quick
Discussion in 'Technical Chat' started by tacowithbeans, Apr 16, 2012.
  1. Apr 16, 2012 at 8:13 AM
    tacowithbeans
    tacowithbeans [OP] Member
    michael
    troup, tx
    o7 prerunner lifted 6" by fabtech
    6" suspension lift, custom drive shaft, lime green underbody and airbrushed dash piece
    ok heres the deal my rearend on my 07 taco went out and now i need the ring and pinion, where could i find a ring and pinion for a 2007 tacoma prerunner 2wd non locking no differential lock no limited slip 3.727 ratio or maybe the third member to fit my truck for a reasonable price. ive searched high and low even googled it and nothing
  2. Apr 16, 2012 at 8:19 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Wrecking yard?
    Or pull the third and carry it to a specialty shop and have them rebuild it?
    Both option MUCH cheaper than dealer repair.
  3. Apr 16, 2012 at 8:19 AM
    tacowithbeans
    michael
    troup, tx
    ok ill give em a call and see what they say i appreciate it and im still open to suggestions
  4. Apr 16, 2012 at 8:20 AM
    tacowithbeans
    michael
    troup, tx
    what kind of specialty shop would do that for me?
  5. Apr 16, 2012 at 12:08 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Differential repair shop.
  6. Apr 16, 2012 at 12:15 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Apr 16, 2012 at 12:24 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  8. Apr 16, 2012 at 12:25 PM
    amain
    amain Well-Known Member
    Brian
    Anacortes, Washington USA
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
  9. Apr 16, 2012 at 12:31 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Chase at ECGS is good no doubt. But it's good to support local shops when you can.
    If you're in a major urban area, you should be able to find a good local shop and avoid having to ship a 75lb 3rd member around the country.
    Differential repair is skilled labor with a specialized skill set, but it's not like brain surgery where you want to seek out the nation's top neurosurgeon.
    Now, if you live in East Podunk, and your only choice for miles around is "Bob's All Purpose Shade Tree Repair - If it Rolls Creeps Or Crawls, we can Fix It (I Think)" - then yeah, shipping the third to a known specialty shop makes sense.
    My two cents.
  10. Apr 16, 2012 at 12:46 PM
    mjp2
    NJ
    Totally agree with you. Since he was asking I assumed he's exhausted local options.
    CSB:
    My 6.0 diesel blew head gaskets awhile back. Lots of searching turned up a reputable shop relatively local that had done lots of high-profile work. Flash and fancy. They did a good job on the rebuild but the new gaskets failed in 25k miles. (Black Onyx head gaskets are terrible, as it turns out)
    In that time I had moved farther away from that shop and did some searching closer to home. Stumbled on a shop with a single lift and 2 owner/employees. Gave them a call and they're experts on the specific engine I was having issues with, could name exactly the symptoms I was seeing, and explained how and why things failed after my last rebuild. Took my truck to them and got it back 5 days later, completely rebuilt (cab-off procedure) and running better than it ever has.
    It's the kind of shop that you'd miss if you were staring right at it, but I'd happily bring any of my vehicles to them in the future. Quality work and the best prices I've found.
    /CSB
    OP, good luck with the repairs!
  11. Apr 17, 2012 at 6:34 AM
    tacowithbeans
    michael
    troup, tx
    thanks man i called these people yesterday im not sure yet but i think im going to go with a 4.56 ratio the whole master kit will run me 456 dollars
