Ring and pinion question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by christian06, Sep 1, 2018.
  1. Sep 2, 2018 at 6:46 PM
    christian06
    christian06 [OP] Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Thx for the info
  2. Sep 2, 2018 at 6:46 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I think 4.10's would bring it closest to stock, but for all that money spent on regearing, that is not that big of a difference.
    ColoradoTJ likes this.
  3. Sep 2, 2018 at 6:49 PM
    christian06
    Cali
    True, I'm just want it to run closest to stock, so the tranny ain't hunting for a gear or struggling
  4. Sep 2, 2018 at 6:50 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    OP if you do have the one and only Tacoma that came from the factory with 29" tires and a Toyota OEM mechanical LSD rear axle with 4.56 ratio , I'll swap with you. It would help us both out! Adjust for my 35's and allow you to drive on the interstate with 29" tires without having to run the engine at 5000RPM's. It's a win/win!
  5. Sep 2, 2018 at 6:54 PM
    christian06
    Cali
    I've come to find out that it's actually an 8in with 3.73 gears, my stock tires are 265 70 17s and measure 29.5 inches, I wanna run 33s but don't wanna over rev the motor or struggle it, I want it to be as close to stock as possible
  6. Sep 2, 2018 at 6:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you currently running 33s? If not, just get them mounted and run them and see if you feel the need to regear first.
    Clearwater Bill and Muddinfun like this.
  7. Sep 2, 2018 at 7:02 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Stick with 3.73's with 33's. I don't use the dash speedometer, I have always used GPS. Triple redundant, one on NAV unit, one on Escort 9500ix and one on phone. At 70MPH on the speedometer, with 33's you will actually be going about 73-74MPH. With the tires from the factory, when driving your truck on the interstate, when your speedometer shows 70MPH you are actually traveling at approximately 68.5MPH.
    You are worrying for nothing man. You can spend $1,600 on better mods.
    Just my opinion, I'm out.
  8. Sep 2, 2018 at 7:19 PM
    christian06
    Cali
    Point well taken, I didn't realize it was such a small amount, 1600, that's some good modding money
  9. Sep 2, 2018 at 7:20 PM
    christian06
    Cali
    I don't have 33s yet, but very soon, thx
  10. Sep 2, 2018 at 7:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're gonna love them. It's good your'e doing research and getting your ducks in a row beforehand, but I don't think you'll really need to regear.
    jboudreaux1965 likes this.
  11. Sep 2, 2018 at 8:50 PM
    christian06
    Cali
    I'm usually very thorough about things, I'm computing the actual total cost of lift, tires, brake lines, CB spacers, drive line spacer, Dakar for the rear, ext. Shocks, u bolt flip kit, couple of alignments, and the such...
    Gonna buy spindle 4in lift kit in two weeks when I get back from vaycay
  12. Sep 2, 2018 at 11:01 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Keep in mind, with spindle lift, using FJ wheels, you are looking at like 1.5" spacers in the front and like 3"+ spacers in the back to make them match. Consider different wheels.
  13. Sep 3, 2018 at 7:58 AM
    christian06
    Cali
    ya, that's is not what I want to do, I could stand a small spacer, but 1.5 and 3in is a bit on the sketchy side for me.
    what kind of backspacing should I look for?
  14. Sep 3, 2018 at 8:25 AM
    christian06
    Cali
    nice truck by the way, so your running 4in spindle lift, plus 3in struts ? So, you have 7in of lift?
  15. Sep 4, 2018 at 5:41 PM
    #35
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Thanks bro! And Yes sir 7"
  16. Sep 4, 2018 at 5:42 PM
    #36
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Goto the MaxTrac site, they have all the specs. Or you can call them, very helpful peeps, I called about different wheels I was considering, originally I want to use my FJ wheels, but they said that wouldn't work.
  17. Sep 4, 2018 at 5:47 PM
    #37
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If you wanna know for sure without opening up the diff (and this works on most cars) put it in neutral and jack up the rear. Twist drive shaft and see how many revolutions it takes to spin a tire 360 degrees. That's your ratios.
    From the factory it was 3.73 in your truck. Going to 33s represents approximately a 10% increase in tire size so you'll want to gear down the diff(s) by the same 10% so that suggests 4.10 gears.
    Now this doesn't account for the additional power required to move the extra unsprung weight (and whatever other mods you may add) so 4.30 should have the best "stock-ish" results
  18. Sep 4, 2018 at 8:18 PM
    #38
    christian06
    Cali
    Thanks, that's a sweet ass truck
  19. Sep 4, 2018 at 8:19 PM
    #39
    christian06
    Cali
    Thx for the info
  20. Sep 4, 2018 at 8:24 PM
    #40
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
