Ring and Pinion the Weak Link with a Locker?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunn_runner, Feb 27, 2017.
  1. Feb 27, 2017 at 6:00 PM
    gunn_runner
    gunn_runner [OP] www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Ive been contemplating a rear air locker first, then the front diff after my wallet recovers... Question is about the ring and pinion when locked on 33" tires. So they tend to let go more when a locker is introduced? I plan on regearing as well; are the aftermarket gears stronger than OEM?
  2. Feb 27, 2017 at 7:12 PM
    Pigpen
    Dan
    Northwest Montana
    Nope. With the stock e locker the answer would be yes, but not with an aftermarket locker. East Coast Gear Supply is the go to for most members.
