ring and pinion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paul gallardo, Feb 12, 2010.
  1. Feb 12, 2010 at 8:00 PM
    paul gallardo
    paul gallardo [OP] rc racer
    northridge, ca
    5lug taco access cab
    fog lights,light bar, sport pedals, tire size swap(from 215/70/15 to 235/75/15to31/10.5/15). Crager 15x8 blackies 2.5 inch lift.Dynomax super turbo, AFE intake system.
    Question, does anyone know if the prerunner diff gears will fit the 5lug tacos?
  2. Feb 12, 2010 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Feb 12, 2010 at 8:43 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    CappyCap was able to get 3.73s to fit. Here is a link to his thread.
  4. Feb 13, 2010 at 11:47 PM
    paul gallardo
    northridge, ca
    I read somewhere that the ring & pinion off of an automatic 5lugger would work. It's a 3.53 ratio, don't know if it's enough.
  5. Feb 14, 2010 at 7:32 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Using the Tire Calculator I was able to produce the chart below (using factor tire specs and the current tire specs). IMO, you should re-gear to factory specs. I will be re-gearing to 4.10s soon.
