ring gear size 08 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4cyl, Feb 6, 2014.
  1. Feb 6, 2014 at 6:58 AM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    what ring gear do I have. My truck is a 4cyl 4wd 5 speed manual open diff
  2. Feb 6, 2014 at 9:20 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You have an open 8.4". It's kind of counter-intuitive, because the ring gear still measures 8", just like most other tacoma ring gears. Here's a link that explains it better- http://home.4x4wire.com/erik/diffs/#T100-Tundra
    If you want to regear consider using ECGS, awesome customer service and good warranty- http://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html
  3. Feb 6, 2014 at 6:44 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    thank you. I called Eaton and they only offer the torsen locker for 8.4". The rep said they don't have 8.4"s from after 2006
  4. Feb 6, 2014 at 6:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you want to put in a locker - ARB air locker is the way to go.
  5. Feb 6, 2014 at 6:52 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    I agree an air locker is 100% once engaged, but I like the simplicity and strength of the torsen.
  6. Feb 6, 2014 at 6:54 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I like ur tenacity op, all 5 of your post thus far have been on the same topic. GL with ur searchin.
    6 u got another in when i was typing.
  7. Feb 6, 2014 at 6:57 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    I'm new to forums. But its tough finding info on diffs for me. Feel free to change the topic
  8. Feb 6, 2014 at 6:57 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Is there an actual torsen locker? I've never heard of one. Do you want limited slip or an actual locker?
    I'm not sure that any of the torsen LSs are terribly simple either.
    Just saying...
  9. Feb 6, 2014 at 7:01 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    the torsen is made by Eaton or Detroit. I think it's simple because there isn't any need for a compressor,special fluid or wiring and switches
  10. Feb 6, 2014 at 7:01 PM
    yota243
    E.J.
    north Alabama
    Its a great website for info and most the members are nice and some even helpful. It took me a while to figure most of it out. I only noticed ur other post bc they were new post in some of my subscriptions.
  11. Feb 6, 2014 at 7:07 PM
    yota243
    E.J.
    north Alabama
    All of our work trucks are silverados and they have those "auto lockers" i hate em, they dont engage till ur already spinning which could be to late, plus i think i read that they auto disengage at 20 mph. All those moving parts and them slammimg stuff into and the yanking it out while still moving seems sketchy to me, plus ive hit 70 in my truck with the locker on( was not going 70 just flinging mud that fast off my back tires BOTH BACK TIRES) my $.02
  12. Feb 6, 2014 at 7:10 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    thank you. For the advise. I may call some 4wd shops to see what they offer here in n.m.
  13. Feb 6, 2014 at 7:14 PM
    4cyl
    4cyl [OP] Member
    08 4cyl 4wd
    the torsen uses constant mesh worm gears. Nearly impossible to damage
  14. Feb 6, 2014 at 7:55 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Sorry, I wasn't paying attention. Torsen is a limited slip differential not a "locker."
    You've seen this animation, right?
    http://www.pinterest.com/pin/288582288594272168/
    Anyhow, if a limited slip is what you want - a torsen geared implementation is the way to go.
  15. Feb 7, 2014 at 6:41 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    uhhh there are selectable lockers and auto lockers and just because ONE of the torsens is worm drive doesn't mean you can't wear it out but okay, good luck
  16. Feb 7, 2014 at 7:00 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    As opposed to clutch pack type limited slips, which gradually wear out and become no better than open differentials over time, the torsen design functions as a limited slip for the entire life of the differential.
    Yes, anything mechanical may ultimately wear out and fail.
