Ringing from rear end of truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Mar 11, 2023.
  1. Mar 11, 2023 at 11:36 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Hey guys I have a 2023 tacoma with 500 miles on it. I was on highway today and noticed around 50-60mph I can hear a slight “ringing”/“whine” from the rear of the truck not sure how to exactly describe it but it kinda goes away when I let off the throttle. It’s not super loud but noticeable. Is this normal? 2023 sr5 v6
  2. Mar 11, 2023 at 11:47 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Yes it's normal.
  3. Mar 11, 2023 at 11:51 AM
    Gfenza89
    That’s odd, I heard somewhere it’s just frequency noise . Yours does it?
  4. Mar 11, 2023 at 11:55 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
  5. Mar 11, 2023 at 12:01 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Mine does it too, doesn’t bother me one bit.
    Chew, Canadian Caber and Gfenza89[OP] like this.
  6. Mar 11, 2023 at 12:02 PM
    Gfenza89
    Good to know it’s not a problem
    Junkhead[QUOTED] likes this.
  7. Mar 11, 2023 at 12:04 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    People have had some success with different gear oils but other than the noise it hasn't had any affect with longitivity.
    Junkhead and Gfenza89[OP] like this.
  8. Mar 11, 2023 at 12:09 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Depends what's the truck is singing whether normal or not. My sr5 won't sing a lick....was hoping it could learn something.
  9. Mar 11, 2023 at 12:17 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine does it but it's not the differential. the sound is coming from the exhaust. goes away with premium fuel.
  10. Mar 11, 2023 at 12:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rimshot:
  11. Mar 11, 2023 at 12:30 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Noises are mostly subjective to how you interpret them, so "ringing" could mean a lot of things to lots of people. I regeared my diffs to 5.29 and they make the same amount of noise that they did stock, which is barely any noise at all. Normal gear noise, but that's all. Nothing worse than I've ever heard from any other diff.
    However, my transmission now truly sings in 6th gear at 70+ as a result of spinning so much faster from the 5.29s. I let it sing, I still go 80 at 3400. I think of it as a free concert. Mostly kidding, it is annoying, but harmless and radio drowns it out. It is a ringing noise similar to that of a whistling tea kettle. It's a manual and they are not known for being silent in general. Automatics are usually quiet in comparison to manuals.
    Gfenza89[OP] likes this.
  12. Mar 11, 2023 at 12:46 PM
    Gfenza89
    How you know ?
  13. Mar 11, 2023 at 12:48 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You have a big rectangle echo chamber right above diff.. plus with not much rear cab sound deadening the Tacoma has, that why you hear it more than most other makes.
    Chew and Gfenza89[OP] like this.
  14. Mar 11, 2023 at 1:08 PM
    Gfenza89
    You’re howls too ?
  15. Mar 11, 2023 at 1:29 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    I'll hear some wind noise but nothing from the rear. I also have a tonneau cover so idk
  16. Mar 11, 2023 at 1:30 PM
    na8rboy
    WI
    Yes a bit, but tonneau cover made it quieter, plus once it warms up here, I plan on sound deadening. My 2nd gen howled as well.
  17. Mar 11, 2023 at 1:32 PM
    Gfenza89
    Should I take it to the dealership or am I just wasting my time ?
  18. Mar 11, 2023 at 1:32 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i have the diff whine or drive train drone, whatever the cause is. changing the diff gear oil to amsoil SG had no effect whatsoever on quieting or changing the tone.
  19. Mar 11, 2023 at 1:34 PM
    na8rboy
    WI
    Wasting time in my opinion. Like said they been doing it since 2nd gen came out. Some have had luck changing to different gear lube.
    Chew likes this.
  20. Mar 11, 2023 at 1:36 PM
    Gfenza89
    What about the guys who claim replacing the differential fixes the issues? Why do some make this noise and others don’t ?
