Ringing noise from engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 86ceeten, Mar 2, 2010.
  1. Mar 2, 2010 at 6:35 AM
    86ceeten
    86ceeten [OP] Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Last week I noticed a ringing coming from my engine. Not the normal tick but sounds like a bell ringing, it follows RPM and not vehicle speed and only under acceleration. Doesn't really sound like detonation or valves either. Seems to be coming from the right side. Anybody else ever heard a noise like this before?
    Brian
  2. Mar 2, 2010 at 6:41 AM
    YoterHead
    YoterHead Well-Known Member
    I don't know what it is, but I'm interested. I swear I can hear a faint higher pitched ringing from my engine bay sometimes. :popcorn:
  3. Mar 2, 2010 at 6:49 AM
    86ceeten
    Brian
    NW Florida
    I'm about to head to the dealer. Still under warranty for a few thousand miles. I'll post what they say.
  4. Mar 2, 2010 at 9:08 AM
    86ceeten
    Brian
    NW Florida
    Just like I figured. "bring it back when you can leave it all day" WTH. I would rather have teeth pulled than go to the dealer.
  5. Mar 2, 2010 at 9:14 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Does it happen when idle (not driving)?
  6. Mar 2, 2010 at 10:20 AM
    86ceeten
    Brian
    NW Florida
    I'm dropping it off Thursday morning.
    I cant hear anything at idle, just under acceleration, or when the engine is revved in park.
  7. Mar 2, 2010 at 10:26 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Dirty air filter? When my k&n gets pretty dirty... I get a kinda whistling/ringing sound as it has more trouble pulling air through.
  8. Mar 2, 2010 at 10:45 AM
    86ceeten
    Brian
    NW Florida
    No, brand new K&N. Just did a 30k service, but noticed it before that. Truck also gets Mobil 1 5-30 every 5k with either Purolator or Mobil 1 filters.
  9. Mar 4, 2010 at 8:09 PM
    86ceeten
    Brian
    NW Florida
    Well the dealer had it all day, verified the noise but could not pinpoint it. The service tech put about 20 miles on it with a chassis microphone in various places. They opened a case with "technical" and are waiting on an answer from them. They are hoping to have more info next week. On the plus side, it was detailed when I picked it up and they have my TSB springs on order.
  10. Mar 4, 2010 at 8:41 PM
    lucky
    lucky Well-Known Member
    NB, TX
    07 PreRunnerX4
    TRD 2 CAI Firestone Ride-Rite TSB Leafs Toytec AAL 5100's and OME Blue LED dash
    Bro,
    If your valve train ends up being damaged - tensioners, vvt module, chain gear, and they say its oil pump related, I have a ton of info to share with you - to include case numbers I've opened with Toyota and the BBB.
    The sound mine made first sounded like a wine. It later changed to what could be described as a ring, but was more like a bad pulley sound. At any rate, it wasnt a bad pulley.
    See my post...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/73107-sounds-like-bad-pulley-wish.html
  11. Mar 4, 2010 at 8:43 PM
    lucky
    NB, TX
    07 PreRunnerX4
    Mine had exact symptoms...
  12. Mar 4, 2010 at 8:46 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Oh boy, I remember your troubles, Lucky.
  13. Mar 4, 2010 at 8:56 PM
    86ceeten
    Brian
    NW Florida
    Lucky, your post is what got me worried. I'm glad you posted your story! I'll be sure to keep everyone informed...
  14. Mar 4, 2010 at 9:11 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    hmmmm....i have a whirring noise from my engine when i accelerate. i sure hope its not a sign of things to come. keep us posted.
  15. Mar 21, 2010 at 8:59 PM
    86ceeten
    Brian
    NW Florida
    After keeping my truck all day two different times and doing an "induction system cleaning", their answer was "try some premium in it and let us know what happens". I know damn well what detonation sounds like, and this isn't it. I tried it any way, and low and behold the sound is still there. They did get the spring TSB done without any BS at all though.
  16. Mar 22, 2010 at 5:52 AM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    sub'ing to this thread
    THIS!
    I hate toyota dealerships so much. Whether I'm looking for a new vehicle or getting service work done, I always feel like I'm being treated as if I'm inconveniencing them.
  17. Mar 22, 2010 at 6:05 AM
    86ceeten
    Brian
    NW Florida
    I will have to say, they treated me good. I was expecting the "you are bothering us" treatment but both service reps and the tech were very professional and polite, and both times the truck was cleaned inside and out when I picked it up.
  18. Mar 22, 2010 at 6:22 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    This is a stretch maybe, if its based on rpm, could it be a resonance from the air intake ( i noticed u said right side)?? Culprits could be a dirt buildup , or maybe a mod done.
  19. Mar 22, 2010 at 7:21 AM
    86ceeten
    Brian
    NW Florida
    Sorry, brain fart when I wrote that, it's the left side of the engine.
  20. May 4, 2010 at 6:18 PM
    sage73
    sage73 New Member
    Did you ever get this fixed, my 2010 is doing the same thing
