Ringing noise from rear end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lordjuiceKage, Sep 20, 2021.
  1. Sep 22, 2021 at 7:26 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Zip ties on the drive line are my favorite. Makes the truck sound like it has a huge missfire or exhaust leak
    Stocklocker[QUOTED] and Pablo8 like this.
  2. Sep 22, 2021 at 7:33 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine is is due for leaf spring soak again (at LEAST once per year) I go with a thick/thin oil double hit. I know it's due because it sings to me at various notes due to loads and road speeds. Haven't heard chimes though. How loud is it?
    Have a bud ride in the bed and listen.
    Skydvrr likes this.
  3. Sep 22, 2021 at 7:39 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    good old Amosol lubricant you say ?
  4. Sep 22, 2021 at 7:45 AM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Does this almost sound like a heat shield rattling metal on metal? Reason I ask is I had / have that noise. Would typically only show up on a decelerating right turn. I checked everything I could touch, and could never find it. Almost sounded like it could be a loose spring in the rear drum? At any rate, since my last tire rotation the sound has essentially disappeared. I think the uneven tread on the Cooper ST Maxx were aggravating the situation. On my last rotation I did a 4 way cross rotation (LF to RR, RF to LR) instead of the normal front to back rotation. The sound almost completely went away, and once the cross rotated tires got about 500 miles on them, completely gone now.
    Hopefully the link works. You can hear it here about the 5-6 second mark.
    https://i.imgur.com/kqCXsp2.mp4
    Spent hours under the truck trying to locate and could not. Was about ready to pull the trigger on a gopro to put underneath when the sound went away. Should it return I'll have to do that.
  5. Sep 22, 2021 at 8:29 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Remove ring gear and ringing will stop. Duh. Lol
    Stocklocker and Pablo8 like this.
  6. Sep 22, 2021 at 8:36 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Did that to a fishing buddy of mine when we were camping.
    I took a small bell used for clipping onto the end of a fishing pole.
    Sprayed it a rusty color and tossed it in the dirt while paint was dry. Total camouflage once clipped up high by the trans or above the drive line. Drove him nutz!!
    Also ziptied his tent door zippers together on the outside. That pissed him off good!
  7. Sep 22, 2021 at 9:03 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    OK funny. Maybe not enough to earn a living. But funny. :D:D:rofl:
  8. Sep 22, 2021 at 9:05 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I have used a couple different sprays for the thin soak, side but final is Amsoil HD MP. Dries waxy and no schsteenk. Maybe this year I might try Amsoil Chain Lube.
  9. Sep 22, 2021 at 9:39 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    My sniffer must be super sensitive because I can't stand the smell of the HD MP! But damn it works good!
    Pablo8[QUOTED] likes this.
  10. Sep 22, 2021 at 10:25 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    OK no stink after a couple few minutes, when liquid it does have a reek. But when set, all good.
    airforceb2cc[QUOTED] likes this.
  11. Mar 31, 2023 at 3:31 PM
    TB7
    TB7 Member
    Tarik
    2019 Cement Tacoma TRD Off-Road
    -Front: SPC UCAs, Dirt King LCAs -Rear: OME Dakar Heavy Leafs -2.5" King Shocks + Reservoirs Front + Rear -C4Fabrication Front & Rear Bumpers + Sliders -Prinsu Cab Rack, Leitner Classic Bed Rack -Decked Drawer System -Baja Designs 30" Bar, Amber Corners & Fogs -1552 Analog HD Wheels + 33s
    same issue. cant find the source
  12. Mar 31, 2023 at 7:51 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    He jumped on the chain gang. So will I
  13. Mar 31, 2023 at 8:53 PM
    TB7
    TB7 Member
    Tarik
    definitely not the chain/spare. been through a couple iterations with it now, it was only active between 25-30mph and then around 50mph.
    seems like maybe the bolts for the bed to the frame might be loose, exhaust shield, or god knows what else. gopro didnt help... just gotta work my way around under it i guess!
